August 03, 2025, 04:24:32 AM *
Author Topic: Alternator install  (Read 1358 times)
Mondo Limbo
« on: February 18, 2013, 10:28:16 AM »
I read through many posts here about replacing the alternator - pretty much all agreed about an hour to get the old one out, another hour to get the new one in.  I started on mine (buying the Goldwing alternator for MUCH less than the Valk alternator), and it did take about an hour to get the old one out.  Beat and cut up my hand a little trying to work in that tight space.
To try and avoid a repeat of that, I took the new alternator over to my bench grinder and shaved about 1/4 inch off of the corners of the fins.  The alternator went in in about 5 minutes.
« Reply #1 on: February 18, 2013, 11:11:27 AM »
That be a good tip. Where the hell were you a while back when i installed mine??  uglystupid2 I was 67 when i changed out my altenator and cursed iffin i didn't learn some new and exciting curse words when i changed it out.  2funny It WILL reinstall without modifications but it fer sure took a little while.  crazy2 Do you have pictures of the mod??  cooldude RIDE SAFE.
« Reply #2 on: February 18, 2013, 11:33:50 AM »
If you either remove or loosen the center cover so it can be moved (or removed) to a position where its not interferring, then the alternator goes in like butter without grinding on it
SpidyJ
Murrells Inlet
« Reply #3 on: February 19, 2013, 07:56:49 AM »
What you don't realize is that by grinding those tabs off you have put the entire alternator shell in a very fragile and stressed metallurgical condition.  If your bike resonates at a certain frequency (nobody knows what it is) the entire alternator will crumble or explode.
This is most likely to occur at night, when you have left your cell phone at home.......and......it will probably be raining.
Just sayin'.........
« Last Edit: February 19, 2013, 08:00:32 AM by SpidyJ » Logged
1999 Fast Black Interstate
Peace,
johnnywebb
F6BANGER
Albuquerque NM
« Reply #4 on: February 19, 2013, 08:04:11 AM »
Wow Spidy, Its a damn good thing your not a pessimist......LOL  2funny
« Reply #5 on: February 19, 2013, 08:37:28 AM »
OK, well there it is.....I was wondering if grinding that thing could have an adverse affect.  I didnt know life as we know it could be over.  LOL   Shocked
FLAVALK
Winter Springs, Florida
« Reply #6 on: February 19, 2013, 10:22:34 AM »
Dang! sounds almost as bad as what might happen if you run a car tire  Roll Eyes
