By letting the bike run then shutting it off, and leaving it sit you create condensation. Then it just sits in the oil. I have never started the bike after I park it at the end of the season. I may be wrong on this thinking, and I understand everyone has their own ideas about this.
I have to agree with you 100% on the condensation issue.
Now that I hardly use my Valk.
Letting it sit for 2 or more weeks between uses.
Plenty of heat and humidity in my garage down here in Florida.
When starting now it always blows some white smoke for a bit out of both sides.
When used daily it never has or did.
As for the fans this bike when ideling for 5 or more minutes the fan has always come on.
My idle is set at 900 rpm.
Kicked it up to 1000 rpm and the fan comes on a bit later.
