February 06, 2026, 11:34:29 AM *
Author Topic: OEM grip removal  (Read 1460 times)
Kep
My "Mid-life Crisis "
Indiana
« on: February 28, 2013, 09:42:30 PM »
Removed clutch side cap..grab with channel-locks (gently so as not to marr ends) twist and pull. They have small ears that slide over and into rubber notches in the grip end.
« Last Edit: March 02, 2013, 08:27:40 PM by Kep » Logged
9Ball
« Reply #1 on: March 01, 2013, 12:14:13 AM »
huh?  OK
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Kep
Indiana
« Reply #2 on: March 01, 2013, 04:59:10 AM »
Sorry ..was starting to post pics of removing OEM grips and had trouble posting them..then couldn't delete topic/thread..I'll wait till I get it figured out to finnish..wish there were a simpler way to post pics
« Reply #3 on: March 01, 2013, 06:29:05 AM »
there is...open a free photobucket account, then its just copy and paste
« Reply #4 on: March 01, 2013, 06:31:57 AM »
Channel locks, really?  On a wimpy plastic piece.  The clutch side one always just popped off by hand maybe even too easily.  The throttle side unscrews, dont clamp onto that one
Kep
Indiana
« Reply #5 on: March 01, 2013, 06:38:02 AM »
Slide screwdriver between grip and handlebar , insert spray tube from Liquid Wrench (or WD40) . Spray and let set for a minute or so..then simply twist grip off (if they didn't go crazy with the glue) . Mine came off easy !
« Last Edit: March 02, 2013, 08:51:25 PM by Kep » Logged
Kep
Indiana
« Reply #6 on: March 01, 2013, 06:51:58 AM »
Throttle side is similar , but the end cap simply "un-screws".Insert screwdriver between grip and plastic throttle tube , insert spray tube from Liquid Wrench or WD40 and spray. Let sit a minute or so then twist grip off. It may be necessary to slide the screwdriver around inside the grip to loosen it.
« Last Edit: March 02, 2013, 09:12:49 PM by Kep » Logged
Kep
Indiana
« Reply #7 on: March 01, 2013, 06:55:36 AM »
Smoothe jaw (no-mar) Channel-locks work best...guess you could use your teeth too..but as I said "gently" so as not to marr the finish..unless you aren't saving them..then who cares ?Fudgie says they make a great key-fob !?
Kep
Indiana
« Reply #8 on: March 02, 2013, 09:34:11 PM »
Finally figured out the Justpics ...well pretty much so ..haha.
