February 06, 2026, 06:29:07 PM *
Author Topic: proper lubrication product for splines ans such,that's better  (Read 2257 times)
jimmytee
Elizabethtown,KY
« on: March 03, 2013, 01:59:10 PM »
OK I have read many a post about rear end maint. I've been slowly working on the rear end of my bike. Just finished polishing my rear wheel,post pics later,got my new rear rotor, some o-rings, an oil seal for the drive shaft, new pads, some other misc from partzilla. Stopped by a Honda dealer last Mon to get the lube and they were closed. So the next day I was going by a shop,non Honda, and I thought what the heck, bought some Yamaha "Yamalube" molybdenum disulfide grease that seems it should be OK for the splines and was wondering what you all think. I had also read some who like the belray waterproof grease, so I bought them. I know some use a paste,but the Clymer manual just says " a light coating of molybdenum disulfide grease" Well, just thoughts and opinions?
« Last Edit: March 05, 2013, 04:57:19 AM by jimmytee » Logged
« Reply #1 on: March 03, 2013, 05:17:12 PM »
On the Yamaha lube: read the moly content. If it's in the 2-5% range, it's great for the drive shaft at both ends. The Bel Ray is good for the wheel splines but the Yamaha stuff will work there too.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #2 on: March 03, 2013, 08:40:10 PM »
The Honda dealer that I bought my I/S from (new), said all they used was BelRay waterproof grease.  That is what I have been using for 13 years and the splines look great. Wink
States I Have Ridden In
jimmytee
Elizabethtown,KY
« Reply #3 on: March 04, 2013, 03:05:55 AM »
Thanks for the replies.
Sandy, the Yamaha product doesn't specify percentage. It is simply identified as molybdenum disulfide grease.
Steve K, I thought I had read of some using the Bel Ray for the wheel splines. No problem in 13 years eh?
« Reply #4 on: March 04, 2013, 04:09:50 AM »
I reread the Yammy Lube and it is water resistant with good shear qualities. Don't worry about the exact moly content. It's good for both the wheel and shaft splines.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #5 on: March 04, 2013, 09:29:58 PM »
Yep, no problems.  There are quite a few members using it.  I even put it on the ends of the drive shaft.
Also packed the bearings on my Cycle Mate trailer with the stuff.  Pulling the trailer on hot summer days, I can put my hand on the hubs and they aren't any warmer that the ambient temp.
jimmytee
Elizabethtown,KY
« Reply #6 on: March 05, 2013, 04:55:45 AM »
 crazy2 oh great, I just realized how bad my subject line is worded.
Daniel Meyer
The State of confusion.
« Reply #7 on: March 05, 2013, 06:14:43 AM »
LOL! Yep, and now let's talk about nuts.  2funny
Make sure you torque the axle down before you tighten the 4 nuts that hold the rear end to the swing arm. This is more important than the choice of lube.
CUAgain,
Daniel Meyer
Brian
Monroe, NC
« Reply #8 on: March 05, 2013, 03:33:14 PM »
Where did you buy that Belray grease at? Our Honda dealer wants $9.50.
« Reply #9 on: March 05, 2013, 03:54:03 PM »
The Bel Ray isn't a motorcycle specific grease. Any auto parts store should have it.
jimmytee
Elizabethtown,KY
« Reply #10 on: March 05, 2013, 05:24:25 PM »
Brian, I bought the Bel Ray from a shop in Indpls called Flat Out. I think it was like 6 something.
