January 28, 2026, 11:01:38 PM *
Author Topic: Runs rough when I get on the throttle  (Read 2069 times)
FireValk
« on: June 23, 2009, 04:36:29 PM »
My bike runs and accelerates fine unless I really get on the throttle.  I notice the problem most on the highway in 5th gear.  Something seems to be holding the bike back and it shakes a little.  It runs fine if I am just cruising.  Any suggestions?
« Reply #1 on: June 23, 2009, 11:57:06 PM »
If you are crankin the throttle at 50 or below, a little vibration is normal for a short time.  A kick down to 4th will cure it.  Sixty or above shouldn't happen.  This is just a slight vibration, if it's really shakin, there is a problem.
FireValk
« Reply #2 on: June 24, 2009, 04:08:06 AM »
I get the vibration/shaking above 60.  I can accelerate slowly without a problem but get the moderate shaking when I get on it.  Any ideas where I should start to look?  Maybe synch the carbs?
Warlock
Magnolia, Ms
« Reply #3 on: June 24, 2009, 05:56:58 AM »
Does it sound like the motor is starving for gas? The vibration could be coming from a bad u-joint.
David
FireValk
« Reply #4 on: June 24, 2009, 09:45:30 AM »
It does almost sound like it might be starving for gas.  I have run 2 tanks of gas with Seafoam through it without any noticable change.
mmvalk
Boynton Beach, FL
« Reply #5 on: June 24, 2009, 10:01:53 AM »
RPM?  the bike tends to 'vibrate' a bit when accelearting within the 2500 - 3000 RPM range.  As far as I know, that's normal behavior for a Valk.
Wago
« Reply #6 on: July 01, 2009, 12:26:47 PM »
Fuel valve - probably a bad diaphraghm.  Install repair kit or replace with a Pingel. (test b4 replacing - if the valve won't hold vacuum, repair or replace),
Wago
