February 06, 2026, 03:01:48 PM *
Author Topic: Never prepped 2 year old battery. Still good?  (Read 1219 times)
maniscar
VRCC #2225
Southern NH
« on: March 10, 2013, 09:01:12 AM »
Hello,
Thinking my OEM battery was reaching its end-of-life, I purchased a new YUASA battery from DirectLine back in Oct.2010.   Actually forgot about it as the OEM still starts the bike.  Came acrossed it in my basement the other day.   It is still in the original packaging, never opened, never prepped, etc.
Two questions:
   - Is it still good to use?  i.e. any degradation of the acid/chemicals/cells from sittng that long?
   - If yes, do I use my Batter Tender Plus to charge it?
   Rich  ( '03 Standard )
2003 Valkyrie Standard
MP
North Dakota
« Reply #1 on: March 10, 2013, 09:11:23 AM »
I assume acid never added?  If not, it should be good.
You should use a larger size charger.  I do not remember the details, but the instructions say what size charger, for how long.  I think a Tender is too slow.
MP
"Ridin' with Cycho"
« Reply #2 on: March 10, 2013, 09:13:05 AM »
If it remained dry, it is good to go (add acid and charge).
No, an initial charge should be with more than a battery tender, even a Plus (most tenders will not bring a fully discharged (but still good) battery back to life.  Initial charge should be like 2 amps for 7-10 hours.  It is also said that after filling with new acid, you should wait an hour before commencing the initial charge.  During the first charge, the seal must be left loosely on which will allow for gassing. The release of gasses could be harmful if not done in a ventilated area.
http://www.atbatt.com/batterytimes/how-to-fill-and-charge-yuasa-ytx14-bs-motorcycle-battery/
9Ball
« Reply #3 on: March 10, 2013, 09:22:54 AM »
Instructions come with the battery for activating it.  If you can't find them I'd be glad to scan a copy and send to your email.
Make sure you follow the time requirement after adding the acid before hooking it up to the charger.  You'll feel the battery case get hot right after adding the acid and it needs time to cool off before charging (among other chemistry-related issues with the activation process).
A battery tender will not be adequate....You need a charger with 1.4 to 2 Amp/hr rate...don't charge on a higher rate in order to cut time or you may "cook" your new battery.
« Last Edit: March 10, 2013, 09:26:00 AM by 9Ball » Logged
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
maniscar
VRCC #2225
Southern NH
« Reply #4 on: March 10, 2013, 11:20:03 AM »
Jess, 9Ball, MB
Thanks for the quick responses!   Good to know I don't have to replace it.
Box was never opened.  Battery is dry.   I'll see if I can borrow a better charger.  If not, it's off to the auto stores or Wal-Mart.
Thanks again.
  Rich
tonyfan70
Apparently they know you?
Central Illinois
« Reply #5 on: March 10, 2013, 03:44:22 PM »
Pretty sure it's no good. If you send it to me, I will properly dispose of it for you free of charge. Smiley
no pun intended.
1997 Standard. Original bumblebee tin stored.
1998 Magna 750
2000 POS Sportsman 500
maniscar
VRCC #2225
Southern NH
« Reply #6 on: March 10, 2013, 05:24:12 PM »
no pun intended.
 Smiley
« Reply #7 on: March 10, 2013, 07:42:43 PM »
I got an Interstate battery for my wing and saved it dry. Over a year later, I installed the acid and charged it overnight on a CTEK 3300 smart charger. That's about 1.5 amps. Two years later it's still cranking like new.
