February 06, 2026, 03:02:14 PM *
Author Topic: Found this interesting graph regarding keihin carb jetting  (Read 1333 times)
9Ball
« on: March 12, 2013, 06:15:19 AM »
thought I would share...might help someone understand jetting effectiveness when changing from stock equipment to aftermarket pipes, etc.  Gives an idea how setting pilots, shimming needles, or going with bigger mains relates to throttle position.
All Keihin carburetors are pre-jetted for bolt-on operation. Carburetors are jetted using stock motorcycles and watercrafts. Any major engine modifications like higher compression pistons and racing exhaust systems may require minor jetting adjustments. The following is a guideline for jetting Keihin carburetors. Perform the jetting in the order given below.
« Last Edit: March 12, 2013, 06:20:41 AM by 9Ball » Logged
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
pancho
Bonanza Arkansas
« Reply #1 on: March 12, 2013, 07:47:01 AM »
That is interesting info,,, I saved it, thanks for posting.
