February 06, 2026, 03:01:57 PM *
Author Topic: reason for the fuel rail leaking  (Read 2493 times)
Brian
Monroe, NC
« on: March 27, 2013, 03:24:57 AM »
I found corrosion at all O-rings. Could this be from my choice of O-ring lube 7 years ago or water? Notice there is more corrosion on the gas side of the O-ring.
Thunderbolt
Worthington Springs FL.
« Reply #1 on: March 27, 2013, 04:01:02 AM »
I'm thinking it's that doggone ethanol gasoline or as you said water in the gasoline.  I just cleaned up the carbs on the Interstate and put new o-rings on the bowls, they looked similar.  Probably will be doing the o-rings on the fuel rails next, I still smell a little gasoline.
« Reply #2 on: March 27, 2013, 05:02:23 AM »
Great pic Brian! A good example why fuel would leak by th O-rings.
My rides:
Farther
Quimper Peninsula, WA
« Reply #3 on: March 27, 2013, 08:00:50 AM »
What material is corroding?
~Farther
« Reply #4 on: March 27, 2013, 08:07:15 AM »
o-ring lube 7 yrs ago? what type did u use? only silicone grease aka dielectric should be used.
that's what it looks like, not corrosion
« Last Edit: March 27, 2013, 08:17:36 PM by CA » Logged
Thrud
2000 Valkyrie Interstate
« Reply #5 on: March 27, 2013, 11:48:07 AM »
Why are you putting lube on an o-ring that is exposed to fuel?  Does the shop manual call for lubrication?
AZdougness
« Reply #6 on: March 27, 2013, 12:07:21 PM »
My understanding is it extends the life of the o-rings considerably. Between heat, pressure, corroding substances, and dryness there are a lot of possible damaging conditions that can occur. Lubing with the proper substance per material type or area of application is important. It's like when installing a new oil filter you smear a coat of oil on the big o-ring around the base seal, though the manual does call for it in this case.
whitestroke
San Pedro, Ca.
« Reply #7 on: March 27, 2013, 06:01:43 PM »
Humm, kinda looks like the stuff I found in my slow jets.
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
YoungPUP
Valparaiso, In
« Reply #8 on: March 27, 2013, 06:36:12 PM »
Looks like the material I found in the bottom of my float bowls during last seasons carb rebuild do to plugged slows.
99 STD (Under construction)
Brian
Monroe, NC
« Reply #9 on: March 28, 2013, 02:52:15 AM »
The ring of white stuff in the carb body port did leave behind a slight marking or stain in the zinc after cleaning. The sidewalls of the port were not pitted. I may have used plumbers grease that is waterproof. I feel this may be the result of it reacting with the gas. This time I used the dielectric silicone. The term "corrosion" may have been a poor choice of words. It was easily removed with a round wood toothpick. I found the toothpicks worked better than the plastic pick that redeye sent in their kit.
