November 25, 2025, 07:30:06 PM *
Author Topic: Leaking Radiator Hose (Jeep not Valk)  (Read 1225 times)
YoungPUP
Valparaiso, In
« on: March 29, 2013, 05:36:31 PM »
I've been fighting with a leaking upper radiator hose on my wifes Jeep Grand Cherokee with the 4.0 Inline 6.  I can not get it to stop leaking at the thermostat housing.  Have changed the hose, the worm gear style clamps, switched to the Gates power grip clamp (think heat shrink tubing). The last straw was using #2 Permatex sealant on the hose fitting and then reinstalling the hose and clamp. IT still leaks after all this. Help!
99 STD (Under construction)
Michvalk
Remus, Mi
« Reply #1 on: March 29, 2013, 05:40:17 PM »
Crack in the housing? That's about all thats left cooldude
YoungPUP
Valparaiso, In
« Reply #2 on: March 29, 2013, 05:50:24 PM »
That's why I asked.....Standing too close to the problem I never would have thought of that.  Thankyou!
« Reply #3 on: March 30, 2013, 11:30:50 AM »
+1 Good luck.
My rides:
« Reply #4 on: March 30, 2013, 01:00:50 PM »
Does your Jeep have a chrome thermo housing?     If yes,
Toss the damn thing and get a dull metal one.
I fought a chrome thermo housing on a 502  Chevy in my Chevelle for about a year.
Nice thing about it, it only ran on the Drag Strip.    Make a run, let it cool till next round and fill the radiator back up.
An old time drag racer happened to come by.  He looked the 502 all over, and asked how I got the thermo housing to quit leaking.    Told him it leaks.    He lest, came back with a steel one and a gskt.    Said put this on it, it will quit.
Changed it out between runs, and when I sold it 3 years later, it still had not leaked again.
YoungPUP
Valparaiso, In
« Reply #5 on: March 30, 2013, 08:59:23 PM »
Found it!  Take the hose off and look at the thermostat neck no crack.  Put the hose back on and tighten the clamp and the crack opens up.  2 new hoses, 4 new clamps, 2 gallons of coolant, a $10 bottle of cooling system dye for the uv light, and you guys fixed it without ever seeing it with a $7 thermostat housing.   Thankyou.
« Reply #6 on: March 30, 2013, 09:56:45 PM »
   Trust me when i tell you-IF the situation presents itself again-yer ready fer it now.  Wink It are called-experience.  cooldude Glad you got er done.  coolsmiley RIDE SAFE.
« Reply #7 on: March 31, 2013, 06:29:19 AM »
Remember to use the same coolant mixture that we use in the bikes. NO tap water. Use distilled water for the mixture.
YoungPUP
Valparaiso, In
« Reply #8 on: March 31, 2013, 09:24:03 AM »
Refilling the radiator is the easy part.  Got lazy a few years ago and started using th 50/50 premix.
