November 19, 2025, 02:46:30 PM *
Author Topic: Deuce Riser Advice Please  (Read 3335 times)
« on: June 25, 2009, 06:07:18 PM »
I reeeeealy need some more rise outta my bars.  Without having to buy a new set of bars, I've been looking for risers instead.  Been doing alot of reading on here and elsewhere and have decided on a set of Deuce risers.
However.....There seems to be deuce risers and then there are deuce "style" risers.  What's the difference.
Didn't really want to get too spendy with the geniune HD deuce risers, so I've found a couple of alternatives and wanted to know what you guys thought of 'em.
Do any of you guys know anything about these?.....
http://www.bkrider.com/Bkrider/product.aspx?Sku=1000281
Or these?.......
http://www.jpcycles.com/Search/ProductDetail?sku=5000728&N=274986%2028000499&Ne=755082&Ntk=All&Ntt=&Ns=DefaultSort&results=10&No=30
Or, are there other options that maybe I'm not aware of?  Thanks for the help.   cooldude
« Last Edit: June 25, 2009, 06:12:48 PM by Key Boarder » Logged
« Reply #1 on: June 26, 2009, 07:47:05 AM »
Nobody?   Undecided
Steve K (IA)
Cedar Rapids, Iowa
« Reply #2 on: June 26, 2009, 08:29:05 AM »
They look the same to me.  Someone is making an exact replica.  On my I/S I have LaMonster risers and a Ultimate Big Boy seat.  Works good.  On my Std. I have Deuce risers with an Ultimate King seat.   This works well also.  With the King seat, you sit farther back...the Deuce risers come farther  back than the LaMonsters.  With the LaMonster risers, you don't have to relocate the throttle cables, with the Deuce risers you do.  Remember, you will have to grind that step (boss) off the bottom of the Deuce risers.
States I Have Ridden In
Daniel Meyer
The State of confusion.
« Reply #3 on: June 26, 2009, 10:35:57 AM »
Nobody?   Undecided
Not these:
*snap*sproing*osh!t*
CUAgain,
Daniel Meyer
« Reply #4 on: June 26, 2009, 04:56:38 PM »
KB, I have Deuce risers on My '99 IS supervalk, they came on it when I got it.  Most everyone I know or have read about ordered the HD copies from J & P cycle, (who is having all kinds of sales these days).  The $65 price is cheaper than any others available.
Take a look at this Tim Skelton link.
http://www.timskelton.com/valkyrie/how_to/risers.htm
This is what he says;  According to Mase: "These are from a HD Deuce. Part #56033-00 $149. They rise 5.5" and pullback 2.5". You will have to reroute the throttle cables to the inside of the fork tree. Also, you will need to cut the tab off the bottom (easy to do) and get different length bolts but that is it. It should only take about an hour and a few beers (finish the rest when yer done!)."
The tab cut and throttle cable rerouting inside the triple tree are correct as far as I know.  My seller had put on all braided stainless lines and they are longer, so I can't tell from looking at my bike.  The longer bolts I'm not sure about.  I believe you can use the bolts that come with the risers, but they are SAE not metric, and I believe it is necessary to drill out the riser bolt holes in the tree, but only a few thousands of an inch for the bolts to fit through.  I cannot tell you the specifics, but have read this is a very simple deal to do once you know the correct size bit to use....it just relieves a very small bit of metal from the holes, and even if you want to go back to a metric riser/bolt setup, it will be fine.
Another option would be to look at the SCOOTWORKS catalog, on-line for their fat risers.
http://www.shopscootworks.com/shop/productdetail.htm?browse=-19162&productId=-130392&shopBy=-3096&catalogId=-799
The problem with shopping risers is some give total length, rise, pullback, and others only give a distance higher and back than stock (stock are something like 3 1/8 inches tall). But I do not know if the Scootworks risers are drop in (probably), without drilling, but the II's are aslo listed to require  rerouting the throttle cables.
Now I put the Aeromach/Lamonster (identical but different makers and prices) risers on my first interstate, and they are fancy and expensive, but totally covered by the fairing, and they are the tallest and most pullback you can get without any rerouting or lengthening of cables, and they bolt right up with no drilling.  Only thing you have to do is turn the wire clips on the back of the handlebars around 180* to give the wires/cables a bit more room.  Interestingly, Aeromach and HDL give a bit different information on total rise and pullback for these identical risers
http://www.hondadirectlineusa.com/stores/product.asp?pid=519&str=2&ID=430131648
http://www.aeromachmfg.com/product_p/am-4120c.htm
I am 5'9" with a 33" shirtsleeve, and I liked the Aeromach's fine, but I still wished for a bit taller riser, but with no more pullback.  I was pleased to get the second bike with deuce, and they are like 5.5" tall, but because of the wide valk bars, I sometimes get a little pain in my right throttle wrist on longer rides, and when I am sitting up paying attention in rain or traffic (because of a bit of an angle in wrist to bar fit), as opposed to sitting back in the backrest with my feet up on the HWY pegs.  And turning the bars to full lock, the deuce put your hand close to your thigh (not touching but close). There is always a little play up and down in the bars regardless of which risers you use, but this is more limited in the IS because of the fairing.   Overall, I have decided I like the Lamonster/Aeromach a little better than the deuce because my wrist never gets sore with them.
Finally, for a no frills 4 1/4" riser (a 1/4" taller than most of the 4" risers available), HDL's own house brand Cyclehouse will also bolt right up with no mods, and are also cheap.
http://www.hondadirectlineusa.com/stores/product.asp?pid=468&str=2&ID=430131648
I hope this is some help.
Edit....I did not see the cheaper deuces when I first read your post.  Those are likely made by the same people J & P uses (who is always high)    .......but risers must be bulletproof.
« Last Edit: June 26, 2009, 09:51:02 PM by Jess from VA » Logged
« Reply #5 on: June 26, 2009, 07:07:15 PM »
Jess just about covered it all but I'll throw in my 2 cents. I bought the Harly Duece risers and installed them my self. 1. they were expensive. 2. They still look as good today as the day I installed them. A friend at a machine shop had a huge belt sander and sanded off the shoulder on the bottom of the risers, didn't have to clamp them in a vise ect. to cut the shoulder off, just held them up to the sander and in 60 seconds it was done. 3. Pretty sure a 1/2" drill bit cleans out enough material in the trees to put the duece bolts through. 4. Did have to move the throttle cables (stock) behind the bars but was no big deal.
« Reply #6 on: June 26, 2009, 07:24:11 PM »
Thanks for the advice guys.  I've ordered the Deuce risers from bkrider.  Hope they're quaility...we'll see when they show up.
Not a problem with the shoulder.  I have access to metal working tools....band saw and a belt sander should solve the shoulder problem....again, we'll see when they get here what's the best way to get rid of that shoulder.
Hope they're what I'm looking for and can't wait to try 'em.
btw Daniel.....I'll be sure to stay away from those Custom Chrome risers.  Looks like you almost found out the hard way about 'em.
« Last Edit: June 26, 2009, 07:30:50 PM by Key Boarder » Logged
