March 10, 2026, 06:33:08 AM *
Author Topic: CB over everything electronic  (Read 1735 times)
Jeff K
« on: June 26, 2009, 05:05:36 AM »
Bought a new house, nice home in a rural setting. Some guy down the road is blasting his CB transmissions over everything electronic in my house, radio, TV, computer speakers. It is annoying as hell! Most of the day and half of the night. You can't understand much of what he is saying... but that might just be the way this guy talks.  crazy2
If he doesn't have a dog I may have to go pin his coax. It's getting old fast. Embarrassed
Ghillie
Garland, TX
« Reply #1 on: June 26, 2009, 11:57:53 AM »
there are legal limitations on the power you can put out on a CB, sounds like he is exceeding it
When the people fear government, there is tyranny. When government fears the people, there is liberty.
Jeff K
« Reply #2 on: June 26, 2009, 12:47:53 PM »
I figure he is exceeding power limits, but will the FCC do anything about it?
alph
Eau Claire, WI.
« Reply #3 on: June 26, 2009, 01:42:55 PM »
Call the FCC.  They’ll do a scan of the area of all frequencies, pinpoint the location of the transmitter, and then give the guy a fine for modifying his radio.
gregc
Media Pa.
« Reply #4 on: June 26, 2009, 01:54:01 PM »
  He is boosting his output thru a linear amp, and talking using what they call skip.   He depends on the cloud cover to skip his signal off of to get great distances.  It is illegal as hell,  and the FCC will shut him down and take his equipment, and fine him.   We had a CB business here that did the same thing, but they came thru the churchs pa system and the organ speakers.  Needless to say they are gone now.   There is no filter or anything you can do to stop it, the wires in your house act like an antenna .
Bagger John - #3785
« Reply #5 on: June 26, 2009, 02:44:47 PM »
Multiple items within the quoted paragraph are untrue, especially the bolded text.
For all anyone knows, the radio operator may be employing legal power and the homeowner's Part 15 devices are poorly designed, allowing excessive ingress of RF energy...subsequent rectification and amplification of the superimposed AF energy.
A number of RF suppression measures may be employed to reduce or eliminate RFI, even in the vicinity of megawatt-plus (that's one MILLION watts) transmitters. Commercial broadcasters, the military and industry do it all the time.
Jeff - if you want constructive, legal advice on how to deal with this problem from both yours and the FCC's standpoint, PM me and we'll take the discussion off-board.
A pin in the coax is merely asking for a bullet. In a number of states, the CBer/homeowner would be within his rights to employ force if accosted and threatened by a trespasser. Further, those who view property damage as a means to resolve conflict - especially one of this nature, where federal regulations and jurisdiction come into play - ought to think twice about giving others that advice due to its potential ramifications.
« Last Edit: June 26, 2009, 03:11:27 PM by Bagger John - #3785 » Logged
Ghillie
Garland, TX
« Reply #6 on: June 26, 2009, 03:45:55 PM »
I don't see that anyone here suggested that property damage was a solution other than the original poster. It appears that all suggestions were related to contacting the FCC
Bagger John - #3785
« Reply #7 on: June 26, 2009, 03:54:42 PM »
I've seen it come up here before, and on a number of other forums over the years. Bad idea.
Jeff K
« Reply #8 on: June 26, 2009, 04:27:14 PM »
Don't worry, I would never have done that. Besides, I found the guy, he is about 450 ft away from me, back in the trees, and he has two BIG dogs behind his fence. he has two antennas that are about the size of his house. his signal is coming through stereo equipment that isn't even turned on.
Black Pearl's Captain
Emerald Coast
« Reply #9 on: June 26, 2009, 05:00:33 PM »
Do you have any cable TV service in your area? If so, let them know about the transmitter interference. They suffer from this type of illegal tranmission too so they might have more pull in getting him to go legal. Other than that call the FCC.
One other option would be to ask him to install a filter on his transmitters. He might be willing to do that rather then talk to the FCC about his illegal operations (if he is illegal).
Raymond
« Reply #10 on: June 26, 2009, 05:11:11 PM »
Have you ever tuned around on a CB to see if you can hear him and find out what channel he is on, what his handle is, etc....  It might be a Ham Radio operator and not a CB'er.  Although most of the time it is found to be the Citizen Band, but there is a possibility that it is Ham related.
If he is a ham, listen on a scanner for his callsign, then you can report him to the FCC.  His transmissions, if he is at the legal limit, are protected by the FCC.  But if he is causing interferrence from that distance, it sounds like he has a problem with his station and needs to take a look at it, or he is way above the legal limit.
Just my $.02
Hay  Cool
