November 19, 2025, 01:06:51 PM
K&N filter with prefilter - question
Topic: K&N filter with prefilter - question (Read 1797 times)
FLATSIX
Heist o/d Berg BELGIUM
June 26, 2009, 05:24:39 AM »
Hi There !
A simple question : when using a K&N filter + pre-filter, do you take away the original joint that sits between the upper and underpart of the airbox - or do you mount this joint as you do with the original airfilter.
standard '97 - european F6C - red & white - 27.000 KM
9Ball
Re: K&N filter with prefilter - question
June 26, 2009, 06:20:17 AM »
if you're talking about the o-ring type seal, you won't need it as the K&N has the grooves that replace it. Put it in a drawer in case you go back to stock air filter.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
FLATSIX
June 26, 2009, 02:34:46 PM »
O.K. I putt it in a drawer - THANKS
=> InZane XXV
