January 28, 2026, 11:03:45 PM *
Author Topic: electrical guru advice needed  (Read 2454 times)
KCvalk
Alexandria VA
« on: June 26, 2009, 10:50:22 AM »
ok unplugged all the new gauges and acc lights but still having a drain on the battery.
ive eliminated the new stuff ive added in the last 6-8 months but i still have a slow drain on the battery
it charges up and i get a good green on the kyurk volt meter when riding, but it sits for 24 hrs and the battery is too low to start up.
 im not fantastic with 12 volt system but i understand the basics and need to find where this short is.
what's my next move...
the armor of the Valkyries "sheds a strange flickering light, which flashes up over the northern skies" making the aurora.
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #1 on: June 26, 2009, 10:54:22 AM »
How old is your battery?
Black Dog
Don't you know...
KCvalk
Alexandria VA
« Reply #2 on: June 26, 2009, 11:09:07 AM »
at least a year prob more like 2 or 2.5
DeathWishBikerDude
« Reply #3 on: June 26, 2009, 11:51:35 AM »
Buy a battery.
Bruce J.
Cleveland, OH
« Reply #4 on: June 26, 2009, 12:44:40 PM »
You might try disconnecting the battery overnight, then check the charge. If it is bad, it will probably discharge on its own.
« Reply #5 on: June 26, 2009, 02:32:40 PM »
Try this, disconnect the ground cable from the battery and touch it to the negative post a few times to see if you see a tiny spark.  If you see it with everything off, you've got a drain on the battery.  If no spark, the battery is probly bad.  Hoser
JimC
SE Wisconsin
« Reply #6 on: June 26, 2009, 07:25:54 PM »
Or,
you can put an automotive test light on the negative side, pull the cable off, clip the light on the battery post and the other end on the cable. If you have a drain it will light up, sometimes bright, sometimes faintly.
If it lights at all, start pulling fuses one at a time until the light goes out. When the light goes out after pulling a fuse, you have found your drain, troubleshoot the wires or the item from there.
Jim
Jim Callaghan    SE Wisconsin
Kingbee
VRCC# 576
Northern Illinois
« Reply #7 on: June 27, 2009, 07:12:53 AM »
If you have an Interstate, there will be a small spark at the battery cable, as there's a small drain from the radio and CB memorys.
1999 Interstate
2000 Interstate
2004 Rune
Oyeaa
« Reply #8 on: June 27, 2009, 05:04:33 PM »
If you have the Interstate model you should have a continuous drain on the battery.
Old  Post of mine:
I have a 2000 Interstate, 43,000 miles battery is not original equipment but I am uncertain how old it is. The bike has given me problems starting. So I have plugged in the battery tender overnight and the next morning it cranks over very nicely and fires right up. Ride to work and 12 hours later (yeah 12 hour days suck) it cranks very slowly and is barely able to start. Ride home is long enough to recharge it and when home it will crank very strongly. Until the next morning it is low again.
My initial thought was poor older battery not holding a charge, replace it and all will be good. So I ordered a battery and it came in Friday, today I thought that I should do a little more investigating to make sure it is a battery issue and not a charging system failure or a trickle discharge issue that can be corrected.
So I got out my trusty service manual and went to section 16
Voltage Inspection
Checked voltage of battery with bike off. About 12 volts ( a little low should be about 13)
Charging System Inspection
Current leakage test
Bike off, disconnect the negative terminal cable and put an ammeter in between the post and the cable. Current leakage initially was high and then as all the capacitors finished charging the leakage current dropped off to 2.2 milliamps (2.2mA). The manual states it should be less than 0.1 milliamps (0.1mA) so what I measured is a little high based on the manual. I think, however, that the manual states the appropriate value for the STD and Tourer not the Interstate. The Interstate has memory functions that draw current all the time in the dash for the clock memory and in the radio for the radio memory. I just do not know what they should be. Here is what happened when I unplugged the radio from the harness the leakage dropped to 1.0mA and when I unplugged the dash it dropped to zero. Plugged in the radio again and leakage went to 1.2mA and then plugged in the dash and it went back to 2.2mA.
Reconnected everything and started the bike and checked battery voltage with bike running. 13-14.5 volts depending on RPM. Seems right based on the manual so that confirms the alternator is working fine.
After a lot of looking for a problem, that was not there, the new battery DID solve the original problem, and I have had no issues, even though there is always a 2.2 milliamp draw on the battery.
I hope this helps
 Smiley
DeathWishBikerDude
« Reply #9 on: June 28, 2009, 06:31:49 PM »
My battery failed this evening.
Started fine this morning when I moved the bike to let other family members out of the driveway.
This evening,not even any indicator lights.
Motorcycle batteries are notorious for dieing at the worst times.
I'm just glad I was not on the road.
I ordered this battery off the bay,$50 delivered to my door.
I've known guys to spend over $100 on yuasa batteries and have gotten less than a year from them.
Here goes nothing.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&_rdc=1&ru=http%3A%2F%2Fshop.ebay.com%3A80%2F%3F_from%3DR40%26_trksid%3Dp3907.m38.l1313%26_nkw%3D180233672528%26_sacat%3DSee-All-Categories%26_fvi%3D1&item=180233672528&viewitem=
« Last Edit: June 28, 2009, 06:43:49 PM by DeathWishBikerDude » Logged
