February 06, 2026, 06:57:04 PM *
Author Topic: Starter Question  (Read 1202 times)
wildthang1949
Henderson, Tn
« on: April 11, 2013, 12:15:38 PM »
It seems my bike won't start unless it is in neutral. With it in gear and the clutch pulled back it won't make a sound. Put it in neutral and she fires up.....have I got a bad switch somewhere? Much thanks....
Farther
Quimper Peninsula, WA
« Reply #1 on: April 11, 2013, 12:19:28 PM »
Is your kickstand up?
~Farther
wildthang1949
Henderson, Tn
« Reply #2 on: April 11, 2013, 12:27:40 PM »
yep, it is up
Michvalk
Remus, Mi
« Reply #3 on: April 11, 2013, 12:30:15 PM »
Clutch switch un plugged? It's activated by the lever. There are two wires attached with pushon connectors cooldude
« Reply #4 on: April 11, 2013, 12:35:17 PM »
The clutch lever switch could very well just be dirty. Can you hear it ? If not, spray it good.
wildthang1949
Henderson, Tn
« Reply #5 on: April 11, 2013, 12:59:36 PM »
I sand papered the contacts on the switch and it now works perfect.....thanks so much......yall the best
