February 06, 2026, 06:55:20 PM *
Author Topic: Adding the Harley Road King Leather Saddlebags Write Up  (Read 2963 times)
jimmytee
Elizabethtown,KY
« on: April 14, 2013, 06:21:03 AM »
Hey folks. Got a few pics and a few words for anyone interested. I bought my 2000 Standard, it came with some Champion Bags that were not mounted and needed some TLC. Really just a good paint job. A shame, since they already matched the red of my Valkyrie. But they had been tossed around a garage for a few years and showed it. I started the process of refinishing them, but my patience for such tasks is small. I had subsequently ordered a Woody's fairing http://woodysfairings.com/index.html which I chose to have wrapped in leather by Northern Michigan Leather Co. http://motorcyclefairingbra.com/Gallery.html.
Well because I chose to leather wrap the fairing, I thought it was fitting to keep the leather theme around back as well. I really like BFs mustang bags, but when initially looking at price they were upwards of $900. I believe they can be had a little cheaper now. The other option I came up with was the Road King Bags. I paid like $350 for a set that are brand new off e-bay. I always thought they looked pretty good. They were my favorite bag vs. the hard bags on the Road Kings. They are leather on the outside with a hard inner shell. The other thing about them is that there is a speaker grill kit that will allow me to put 6x9 speakers in the lids. That will be forth coming. Got to cash flow some home expenses first cooldude
Obviously there are issues when mounting anything not directly designed for our bikes. So here are a few pics that show what I did.
I had a good solid mounting surface to start with. The Champion bags mentioned above, mounted with a large flat chromed piece that provides an excellent surface to mount onto. It is very solid.
In order to get the spacing to accommodate things like the shocks, clearing the ultimate king big boy( fat boy)  seat, I ended up using this.
It is a solid PVC board used for replacing exterior trim on your house. I chose a  3/4" x6" board that came 8ft. Long
I sandwiched two pieces together to get the desired thickness. I used PVC glue.  I then mad my measurements for the holes I'd use.  Using the boards as spacers allowed me to mount the boards to the chrome brackets and then use the Harley Bag mounting holes to mount to the boards. My positioning also took into account the e-bay knock off bag rails that i ended up paying $192 plus shipping. Total was $211.00.
I made rough cuts first and the did a final cut after the mounting holes were determined.
The Harley Bags inner shell is ABS I believe. It is intended to also have support underneath. Besides looks, this was also one of the reasons I got the rails. As a system together, the bags are very, very solid and ready for whatever load I throw at them. I was originally going to weld up a bracket that would come underneath the bags and mimic the way Harley had intended them to be mounted. After receiving the rails, I determined that what I did will be more than sufficient.
The rails have mounting point under the bags and to the rear of the bags. For the underside, I simply cut a piece of 3/4" aluminum tubing to the length needed, polished it and then ran a stainless bolt up through the mounting point and cut tubing and into the bottom of the bags utilizing stainless washers between the tubing and bag. For the rear mounting point, I used a flat aluminum bar, drilled the holes on each end to mount between the rail mounting point and the chrome mounting plate/bracket.
« Reply #1 on: April 14, 2013, 11:34:34 AM »
Jimmytee I would like to see more pictures of the finished project. Ya sort left me hanging.  2funny
« Last Edit: April 15, 2013, 07:11:47 AM by salty1 » Logged
My rides:
jimmytee
Elizabethtown,KY
« Reply #2 on: April 14, 2013, 05:03:07 PM »
Sorry was in a hurry this morning to get on the road. Had a great ride, about 400 miles today cooldude
Here is a couple of pics showing the bags on the bike.
« Last Edit: April 14, 2013, 05:06:18 PM by jimmytee » Logged
« Reply #3 on: April 15, 2013, 07:13:31 AM »
Nice job!   cooldude  I like the leather look too.
My rides:
BigChris99
Hesperia CA
« Reply #4 on: April 15, 2013, 10:45:24 AM »
Looks really good. Thanks for the pics.
In 5th gear.... looking for 6th
VRCC # 35023   IBA # 7849
« Reply #5 on: April 15, 2013, 12:03:11 PM »
Jimmytee excuse my ignorance, but what are the mounting points of the bag rail system to your bike?
« Last Edit: April 15, 2013, 04:50:51 PM by salty1 » Logged
My rides:
jimmytee
Elizabethtown,KY
« Reply #6 on: April 15, 2013, 03:27:44 PM »
Jimmytee excuse my ignorance, but what the mounting points of the bag rail system to your bike?
The rails are secured, via the normal mounting up front on both sides. There are two points in front of the bags on each side . One is the upper shock mount. A longer bolt included in the kit and the other is a bolt just behind the passengers foot rest. There are then two other points on each side. One that comes off the bottom of the outside rails and turns under the saddle bag. The other coming from the rear portion of the rails that protrudes between the saddle bag and the fender. These usually are mounted to the Hondaline saddlebag support and  heat shield. I did what I talked about previously. The back support is attached to the bracket I have and the bottom support,underneath the bags is secured to the saddlebag.
« Reply #7 on: April 15, 2013, 04:55:15 PM »
Thank you. Do you think these knock offs are the same as a Hondaline bag guard?
My rides:
jimmytee
Elizabethtown,KY
« Reply #8 on: April 15, 2013, 07:29:50 PM »
As fat as I can tell, they are exact copies At least these are
