August 21, 2025, 08:08:23 AM *
Author Topic: suggestions to mount mini air horn?  (Read 1205 times)
suthrncop
mobile, AL
« on: June 27, 2009, 07:16:35 PM »
I just put on a Bad Boy air horn, one of those with the little compressor and horn together...anyone have any good suggestion on where I can mount this to get the best sound and kinda hide it a little...I have it where the original horn was right now, but think it sticks out a little too much.........
« Reply #1 on: June 27, 2009, 07:29:36 PM »
Mount it just in front of the rear wheel and in the little cubby hole by the swing arm.
This area:
In the area where that pipe is added........
« Reply #2 on: June 27, 2009, 08:07:19 PM »
Unless you're on an Interstate.  It fits in the pod of an Interstate.
fordmano
San Jose, CA.
« Reply #3 on: June 27, 2009, 09:17:33 PM »
Not if the Factory fog/pod lights are installed!!! Cry
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
« Reply #4 on: June 27, 2009, 10:12:40 PM »
I've had mine where RJ said for 3 years now. The plate on the swingarm can be drilled and I used pop rivets to mount an L bracket. Don't forget to use a relay to isolate the power to the horn. It draws 18 amps and the stock horn button and wires aren't made for this.
suthrncop
mobile, AL
« Reply #5 on: June 28, 2009, 05:24:04 AM »
thanks
Kaz
Green Bay, WI
« Reply #6 on: June 28, 2009, 08:47:42 AM »
You don't say what kind of air horn it is.  I mounted my Stebel air horn in the right side pod of my Interstate and it really wakes you up when I hit the switch.
suthrncop
mobile, AL
« Reply #7 on: June 28, 2009, 09:18:52 AM »
It is a Bad Boyz, bought from Harbor Freight...good and loud, I think it is similar to the Stebel.  I have a Tourer so no pods to mount it in..right now I have a Belly Tank but that is coming off as soon as I get time, so that sounds like a good place for it to go..until then I guess it will just stick out on the side..Thanks for the input..
