February 06, 2026, 07:03:20 PM *
Author Topic: drive line grease  (Read 1185 times)
pancho
Bonanza Arkansas
« on: April 20, 2013, 11:35:36 AM »
Just something else to think about when you pull the driveline,, and a reason why using Honda recommended lubricants makes it a no brainer.
http://www.machinerylubrication.com/Read/1865/grease-compatibility
Momz
ABATE, AMA, & MRF rep.
« Reply #1 on: April 20, 2013, 02:21:15 PM »
I recommend "Guard Dog Moly 525" grease. Guard Dog is a VRCC sponsor too!
A Honda Certified Gold Wing Technician I know uses "Belray Assembly Lube" (with Moly) exclusively.
Some members also use Belray Waterproof Grease" with good results.
Don't forget to replace all three O-rings whenever you service your drive unit.
ALWAYS QUESTION AUTHORITY!
Brian
Monroe, NC
« Reply #2 on: April 20, 2013, 03:48:06 PM »
+1 on the GD-525 on the rear wheel splines, pinion cup and drive shaft. I have also used Lucas water proof green grease on the shaft splines with good luck. But then again I look at all the drive splines every spring regardless of the miles.
