February 06, 2026, 07:04:38 PM *
Author Topic: Wheel Dampeners question......  (Read 1269 times)
Stanley Steamer
Athens, GA
« on: April 21, 2013, 07:30:23 PM »
How often have you guys changed them out??.......I looked at my maintenance log and the last time I changed them was when Smokin Joe helped me back on June 18, 2008......at 70,564 miles......I'm at around 94,000 miles now.....
The ones we used were the ones from HDL that were made for the I/S.....with the metal spacers already in them........seems like there was someone who was making them out of the same stuff as the shock bushings??....... Undecided
Stanley "Steamer"
"Ride Hard or Stay Home"
vanagon40
Greenwood, IN
« Reply #1 on: April 21, 2013, 07:53:45 PM »
You're thinking of Gary "Shock Bushing" Eckermann (aka Þrúðr).  Unfortunately, Gary passed away last year.
My guess is that since you got about 70K out of your first set, you second set should be good for about the same.
« Reply #2 on: April 22, 2013, 03:52:50 AM »
You'll need news ones some day... If you have them on hand,
we'll just inspect them, and change them if needed.
Here's ones that I changed... see the rubber dust?... they seemed
loose, too...
« Reply #3 on: April 22, 2013, 08:39:29 AM »
Taken individually, the spacers will have a bit of slop.
When the flange is installed there will be no slop.
Some clearance is necessary to allow the flange to install.
Reason being the variations from the manufacturing process.
When considering the drive line and inherent noticeable slop,
slop in the flange/bushing is the least contribution to the total
overall sloppiness in the drive line. Transmission, u-joint and splines
are a much greater contributor to the sloppiness.
Stanley Steamer
Athens, GA
« Reply #4 on: April 22, 2013, 02:03:26 PM »
Hubcapsc and myself will be checking the splines and stuff when we replace the rear tire.....those were some of the things I had thought about too..... cooldude
Stanley "Steamer"
