January 28, 2026, 11:05:20 PM *
Author Topic: vacuum hose sizes  (Read 2162 times)
longrider
Vernon, B.C. Canada
« on: June 28, 2009, 03:59:45 PM »
I know this has been discussed many times.  searched shoptalk on my HI speed dial up and just got frustrated, so.  I am pulling the carbs to replace the slows.  It would be wise to install new vacuum lines as well while I am in there.  What size lines are in there and does the petcock take a smaller line?
thanks
Warren
Thunderbolt
Worthington Springs FL.
« Reply #1 on: June 28, 2009, 04:46:08 PM »
technically it is a metric size.  If you use the 5/32, you can throw away those aggrivating little hose clamps.  #6 is same as #3 and #4.  Check the caps on the others and make sure they are not cracked.
Bone
« Reply #2 on: June 28, 2009, 04:51:15 PM »
It is on shop talk.   It's under   "Vent Hose Replacement"
Since the air box was already removed, I decided to also change the small hoses that are connected to the carburetors (on the same side as the enrichment valves).
Notes:
5/32 hose was used instead of 3/16 (no clips required)
1/8 vent caps were used
