February 06, 2026, 08:27:41 PM *
Author Topic: Tire pressure monitor  (Read 1323 times)
maniscar
VRCC #2225
Southern NH
« on: May 01, 2013, 04:40:30 AM »
I did a search for TPM, tire pressure monitor and tiregard with no results.
Has anyone used the Big Bike Parts TireGard system for monitoring tire pressure?  Will the caps work on our 90 degree valves?  Any other problems with this setup?
Or, does anyone have other TPM options?
   Rich
2003 Valkyrie Standard
« Reply #1 on: May 01, 2013, 04:44:55 AM »
I just use a plain ole pressure gauge on a regular basis. Doesn't help though does it.
maniscar
VRCC #2225
Southern NH
« Reply #2 on: May 01, 2013, 05:06:43 AM »
 Smiley  I should have added I want to monitor tire pressure while the bike is moving.  Smiley
« Reply #3 on: May 01, 2013, 06:24:57 AM »
I know, thats what its for. I just couldn't resist the post.
Cliff
Manchester, NH
« Reply #4 on: May 01, 2013, 08:45:16 AM »
   Rich
I use the Big bike parts TPMS system ... but I have the 45° billet stems.  I see no reason why they wouldn't work on the 90° stems.
VRCC # 29680
« Reply #5 on: May 01, 2013, 10:42:48 AM »
Are you sure they do that?
I am with the impression they only show when the tire gets to a low pressure point that you set.
BonS
Blue Springs, MO
« Reply #6 on: May 01, 2013, 12:01:10 PM »
I have the Doran Manufacturing TPMS (~$200). It's a full featured system for motorcycles, trikes and cars. It runs on the bikes 12V system so no batteries to change in the head unit. It comes with thread-on sensors for the valve stems but it also comes with special, steel, valve stems that allow you to mount the TPMS sensors inside the tire. I didn't use their stems so mine are mounted on the outside. My complaint is that the TPMS sensors make for a leak path when they are screwed on the outside of the tire. And, since I use balancing beads, I lose air whenever I remove the sensors to measure or add air. I'm going to convert my system to use their valve stems and put the sensors inside the tire when I get motivated. My other complaint is that when the bike is turned off current tire pressure indication is lost. Since the TPMS sensors only transmit once every few minutes, to conserve battery life, it may take 5 minutes before they have reported in. Don't worry too much about this because if there is a sudden loss of air pressure they transmit immediately and the head unit goes into alarm. But is inconvenient when heading out of the garage and you can't get an immediate update to know if you should top-off  before leaving home.
The TireGard handlebar mounted system looks interesting and the head unit is battery powered. So, I hope others will chime in with their experiences using it other products.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #7 on: May 01, 2013, 12:49:31 PM »
I've got the TireGuard/Big Bike Things TPMS on both my bikes, although not with the handlebar mounted receiver.  My receiver can be used as a key fob.
The system consists of a programmable receiver and a front and rear transmitter.  The transmitters take the place of the valve stem caps. They are a little large-looking, but do not weigh much.
The system monitors tire pressure and internal tire temperature as you ride.  Like BonS' units, it transmits every few minutes.  The system stays active for about 20 minutes after the bike is parked, and the last transmitted data is saved.  When you turn the system back on the next time you use the bike, it takes a 1 psi change from the last recorded pressure for updates to start.  These are battery saving features.
High and low pressure, and high and low temperature alarm levels can be set.  It gives an audible alarm and the display flashes when a threshold is crossed.
Mine consistently read 1 to 1.5 psi lower than what I measure using a digital pressure guage.  This is consistent bike-to-bike, so it's either by design in the TPMS, or my digital guage is off.  It's no big deal to me, since what I'm interested in is relative changes, especially dramatic ones.
They work fine with 90° valve stems.  I would recommend all metal stems because the (even slight) extra bulk of the transmitters will add to the forces working against the base of the valve stem.  I would NEVER use them with OEM stems if the plastic support piece for the OEM stems were not also in place.  They would work very well with stubby straight stems.
They also work fine if you are running Ride-On balancing and sealing compound in your tires, which is not true with all internally mounted TPMS systems.
I'm happy enough with the product that I would buy them again.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
maniscar
VRCC #2225
Southern NH
« Reply #8 on: May 02, 2013, 09:35:32 AM »
Yep, that's what I would mainly want to monitor, the tire losing pressure and giving me enough time to get to the side of the road.
  Rich
maniscar
VRCC #2225
Southern NH
« Reply #9 on: May 02, 2013, 09:37:26 AM »
Thanks BonS.  Good info!
maniscar
VRCC #2225
Southern NH
« Reply #10 on: May 02, 2013, 09:47:37 AM »
Thanks Valkpilot!   I wasn't sure if the position mattered.  I've only seen a few pictures and those showed the vertical stems.  I was concerned about using the OEM valve stems with the added weight (although minimal).  Good to know it's not an issue.  Sounds like you didn't need to add any weights to counteract it (??).
I do have the plastic "thingy" installed to hold the valve stem, but plan to update to the metal stems with the next tire change.
   Rich
Valkpilot
Corinth, Texas
« Reply #11 on: May 02, 2013, 09:49:43 AM »
   Rich
I use Ride-On balancing compound, so no wheel weights required.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
BobB
« Reply #12 on: May 04, 2013, 06:16:21 PM »
+1 on the Doran TPMS.  One additional drawback not mentioned above is that the sending units in the tires have an advertised battery life of 2 years and the batteries are not replaceable.  You must get new units.  They send current tire pressure every 6 minutes while they are installed.  You can wire the main display unit to either switched 12v or directly to your battery.
