February 06, 2026, 08:29:05 PM *
Author Topic: ground wire  (Read 1617 times)
Bigun
VRCC# 32964
Monroe, Iowa
« on: May 02, 2013, 04:12:28 PM »
can anyone tell me where the main ground off the battery mounts to the frame? Im down to this to give it another go on starting.
1999 Valkyrie Interstate
pancho
Bonanza Arkansas
« Reply #1 on: May 02, 2013, 04:35:15 PM »
Left side of the bike, clutch cover bolt, right below the removable frame ext., directly behind the foot peg mounting plate. Also holds a retainer for a couple of breather/drain hoses.
Brian
Monroe, NC
« Reply #2 on: May 02, 2013, 04:36:59 PM »
One the left side of the bike, look between the frame and the alternator cover you should see a heavy gauge wire attached to the back end of the engine. I have not followed up to the battery. Maybe a good place to start.
Bigun
VRCC# 32964
Monroe, Iowa
« Reply #3 on: May 02, 2013, 06:04:33 PM »
thank you  cooldude
