February 06, 2026, 08:29:07 PM *
Author Topic: I sure am glad I didn't Bet  (Read 2246 times)
BIG--T
The Twilight Zone
« on: May 03, 2013, 07:26:18 AM »
Because I woulda lost my arse!! Coming off the engine guard on my 99 IS there is a 4" bracket that is welded to the smaller round brace. I was going to put my Kury ISO Wings from my standard on the IS but it won't work. I have a 4" extender now and would need a 8" to make it work!  Wonder what is the purpose of the brace since my standard don't have one?
« Reply #1 on: May 03, 2013, 07:50:21 AM »
Where is this piece located?
Only bracket, so to speak, I know of on a I/S is the horn bracket in the right front.
Michvalk
Remus, Mi
« Reply #2 on: May 03, 2013, 08:36:43 AM »
Well, for one thing, the I/S takes an entirely different bracket than the standard. If you don't have the pods mounted the bracket you see is the mount for said pods cooldude
« Reply #3 on: May 03, 2013, 08:48:37 AM »
Aren't you talking about these tabs on each side near the 19 & 11... ?
Tourers and Stds don't have them, I don't know what they are for...
DenverDave
Out past Mars ain't no speed limit -Mojo
« Reply #4 on: May 03, 2013, 10:03:34 AM »
On the I/S there are two small air scoops welded between the curved bracket and the sort of straight bars that bolt below the valve cover.  They are  there either to add air flow to the bottom of the valve cover or to keep your foot cooler, or both.
Some people have cut them off to make mounting highway pegs a littler easier.
Dave
1999 interstate green/silver
Denver, Colorado
VRCC#32819
VRCCDS#0238
BIG--T
The Twilight Zone
« Reply #5 on: May 03, 2013, 10:13:11 AM »
Thanks guys and Dave I believe you're right and I'm thinking about cutting mine off. For you I/S owners, what purpose does it serve?
BIG--T
The Twilight Zone
« Reply #6 on: May 03, 2013, 11:49:39 AM »
Yes RJ it is right behind my horn where the round brace is welded to the engine guard.  Wink
« Reply #7 on: May 03, 2013, 11:53:42 AM »
I think that is the one on an I/S to deflect hot air off your feet.
I haven't been into the front end of an I/S for awhile and my remember isn't up to snuff anymore.
Michvalk
Remus, Mi
« Reply #8 on: May 03, 2013, 01:44:23 PM »
Yes, that piece is to direct airflow. I cut some off mine to get the pegs I added to fit like I wanted. The Baker wings for an I/S attach to the top of the pods using the provided screws in place of the two screws on the top of the pods cooldude
BIG--T
The Twilight Zone
« Reply #9 on: May 03, 2013, 06:00:53 PM »
Yes it looks like it would direct air but I would have thought there would be one  on the other side as well. Undecided
BIG--T
The Twilight Zone
« Reply #10 on: May 03, 2013, 06:03:37 PM »
So when you cut it off, did it mess up the chrome?
Michvalk
Remus, Mi
« Reply #11 on: May 03, 2013, 06:50:06 PM »
Just right on the cut.(I used a side grinder/cutoff wheel) I had some silver paint handy and just used a brush and covered the cut with that
PhredValk
Edmonton, Alberta, Canada
« Reply #12 on: May 03, 2013, 08:46:12 PM »
Some time, long ago, someone damaged one side of the engine guard and replaced it with one from  standard/tourer, so the original has the air scoop and the other doesn't.
Fred.
VRCCDS0237
« Reply #13 on: May 03, 2013, 09:07:16 PM »
The air scoops on the IS are the most curious part of the entire bike.  I cannot imagine how they increase or improve airflow in any way (perhaps they were designed to keep the front end from involuntary wheelies).  Cutting them off is no big deal, you cannot see the cut unless you lay down and look, and nail polish keeps rust away.
BigBad1
1999 Interstate
Garner NC
« Reply #14 on: May 03, 2013, 10:33:07 PM »
I too have often wondered what these scoops are for since they were not on my Tourer. I do have them on both sides. I wanted to relocate my hwy pegs but those scoopy thingies were in the way.
BIG--T
The Twilight Zone
« Reply #15 on: May 04, 2013, 08:24:18 AM »
Yes it is very strange!! I wish the Honda engineer would just jump in and tell us! Lol What is strange to me that it's just on one side! Is that to keep your right foot only cool? Grin
I think rather than cutting it, I'll just take the guard off my Standard and put on it. I hope my right foot don't roast!  2funny
RP#62
Gilbert, AZ
« Reply #16 on: May 04, 2013, 08:36:33 AM »
Those are to direct rain into your boots.
BIG--T
The Twilight Zone
« Reply #17 on: May 04, 2013, 08:42:32 AM »
 2funny 2funny
« Reply #18 on: May 04, 2013, 09:39:00 AM »
Hehe.
Hay Cool
BradValk48237
Oak Park, MI
« Reply #19 on: May 04, 2013, 10:32:07 AM »
THey should be on both sides...
Also there is a bracket to help hold the lower part of the I/S radiator pods on, has a grommet like the side covers and a pin in the pod. If you use the standard guard, the bottom of the pod will be loose...
How do I know??? The PO of mine had removed the pods and put on standard engine guards... but tehe pods were included in the sale.... When I went to put them back on, something wasn't right, and being my first Valk, I didn't know any better... they rattled and flopped a bit.... I rigged up a hose clamp and some bolts to secure them down.. later because of an accident I had to replace the guards and put the I/S guards on and the pods are rock solid....
So if your missing the "boot soaker" on the left, either it was cut off or you already have a standard guard there.... if so , how is the bottom of the pod secured? Without the bottom mount, I would be afraid the plastic would crack at the other 2 mounting points..... Or flop a bit/
Just an FYI from someone who has dealt with Rad Pod problems.....
I ended up mounting my ISO pegs to the curve of the main guard.....
Brad
