November 19, 2025, 02:47:04 PM
tacometer
Topic: tacometer (Read 1719 times)
Cruiserman
tacometer
June 29, 2009, 09:19:47 AM »
just up and quit any Ideas
I feel more like I do now,than I did a while ago.
Re: tacometer
June 29, 2009, 09:49:59 AM »
Alternator? Fuse? Broken connection?
Madmike
Campbell River BC, Canada
Re: tacometer
June 29, 2009, 10:14:12 AM »
yellow/bl is the signal wire from the ICM, there is a connector indicated if you trace it back from the instrument head.
If the gauge light is also out it may be a ground problem (green wire), I am
ASSUMING
that the instrument grounds back through the same wire as the bulb.
Are your side stand and oil pressure warning lights coming on? They pick up power off of a bl/br wire that comes into the tach. There is a "card" in the tach, I thought that I had one here to look at but can't find it right now. The wiring diagram is at the back of the manual.
9Ball
Re: tacometer
June 29, 2009, 10:22:37 AM »
Quote from: Cruiserman on June 29, 2009, 09:19:47 AM
you pegged the needle with too much hot sauce...
I'm sure you mean tachometer....
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
=> InZane XXV
