November 25, 2025, 08:02:08 PM *
Author Topic: ignition coil  (Read 1635 times)
zoltan57
Denver, Colorado
« on: May 04, 2013, 02:07:12 PM »
I have a 2000 standard 13 years old.. question how long of life does the ignition coil last?... today I went to start it and it missed no turn over and I hit the starter switch and it started sluggishly. when I got home I started it again to see  and I heard a whiny spinny sound if that makes sence when I started it.  if this is a ignition coil problem is there any other coils you can but other then oem.. and has anyone put one on by themselves and how hard is it to do..
thanks..
emrik
thanks for the inputs... the bike ran fine after I started it.. never stalled at a stop... so im thinking battery or ignition coil... im going to check all connections first ... im thinking my battery maybe 4 years old... if the alternator was bad .. I would have gotten far...
« Last Edit: May 04, 2013, 06:39:39 PM by zoltan57 » Logged
BonS
Blue Springs, MO
« Reply #1 on: May 04, 2013, 02:16:06 PM »
Personally, I don't know anyone that has an ignition coil go bad on a Valkyrie. Whiny, spinny sound? If it follows the rpm then it could be your alternator or perhaps a bad timing belt tensioner bearing. Just guessing. Has the bike been sitting around a lot? This can lead to things like old gas, clogged carburetor jets and even just dry carburetors. All these can make starting difficult.
« Reply #2 on: May 04, 2013, 02:39:03 PM »
Dyna makes a aftermarket coil I have them on mine and really like them. The voltage output on them is quite a bit higher and mount in oem position. I gap my plugs at 40 for a hotter spark. With this said I agree with the previous post.
« Reply #3 on: May 04, 2013, 03:18:12 PM »
Battery ground and hot connections. Is the altenator functioning correctly-putting out juice? Good contact at starter button? Air fuel spark-gots to have all 3 or no go. When it was running smooth or rough? If the alt took a crap you will not get far on just the battery-don't ask me how I know that.  2funny RIDE SAFE.
Denny47
#34898
Grove, Ok.
« Reply #4 on: May 04, 2013, 05:37:19 PM »
Starter bad? Hard to tell exactly what he has going on from the way he described it.
USAF 66-70, F-105 AWCS
ricoman
Sarasota, FL
« Reply #5 on: May 05, 2013, 03:16:06 AM »
I doubt a coil issue. They do go bad but not often.
Zoltan, there are 3 coils and you refer to "the ignition coil".
Check connections and be thinking battery.
The sound may be from the starter and I'm guessing the bike has been sitting for a while.
Maybe charge the battery, start it up and get a hundred miles or so on her-then look at it all again.
jimmytee
Elizabethtown,KY
« Reply #6 on: May 05, 2013, 07:11:53 AM »
thanks..
emrik
Just my interpretation from your post, but it sounds like a weak battery. The ignition coil going bad would have different symptoms. cooldude If the battery was good,either electrical connections or possibly a starter, but given what you've presented,replace your battery if it does it again. It's four years old. cooldude
« Reply #7 on: May 05, 2013, 12:22:01 PM »
It certainly sounds like a bad/low battery, poor battery connection or a dirty starter switch[ see starter switch maintenance in shop talk]. If it does run, you don't have a coil issue.
gregc
Media Pa.
« Reply #8 on: May 05, 2013, 06:20:10 PM »
  Bad coil wouldn't make a noise of any kind.  Though the bike would only run on 4 cylinders, each of the 3 coils fires 2 cylinders.    I would take a guess from the noise you describe, either a started drive or possibly an alternator bearing.   Would need more info to make a better guess, does it get louder when you pull in the clutch lever?   Sometimes the push pin gets dry and make funny noise when the clutch is pulled in. Noise comes from the area of the slave cylinder under the fuel petcock.
jimmytee
Elizabethtown,KY
« Reply #9 on: May 05, 2013, 06:53:26 PM »
Wink The key is in the description Smiley
I have a 2000 standard 13 years old.. question how long of life does the ignition coil last?... today I went to start it and it missed no turn over and I hit the starter switch and it started sluggishly. when I got home I started it again to see  and I heard a whiny spinny sound if that makes sence when I started it.  .... the bike ran fine after I started it.. never stalled at a stop..... im thinking my battery maybe 4 years old...
I interpret the whinny noise as the starter didn't fully engage and just whirled freely. Something that'll happen on a bad /low battery,faulty switch, or connections. cooldude given the discription, IMHO
