July 30, 2025, 09:18:44 PM
front end noise
Topic: front end noise (Read 766 times)
Jruby38
Oxford Mass.
front end noise
May 05, 2013, 06:01:55 PM »
I get a clunking noise in the front when going slow on a bumpy back road. I think its comes from the front brake calipers. They are bolted on tight but I still and I can move them by hand, and the noise seems to stop if I apply the brake lightly. The calipers move on pins and dont fit tight like on a car. Do
pins ware out and need replacing after 100k . Also the radiator has always has been loose and seems to be missing a bolt at the top.
Re: front end noise
May 05, 2013, 07:00:06 PM »
The Valkyrie uses floating front brake calipers. The"clunk"while stopping is normal. Not sure about your radiator. RIDE SAFE.
Denny47
#34898
Grove, Ok.
Re: front end noise
May 05, 2013, 07:41:41 PM »
There should be one bolt at the top center of the radiator. If missing your radiator can tilt forward at the top allowing the turn signals to hit the radiator on full turn.
1997 Green/Cream Tourer w/ Cobra 6/6 exhaust, 2012 Pearl White Goldwing
USAF 66-70, F-105 AWCS
=> InZane XXV
