April 28, 2026, 07:39:04 PM *
Author Topic: Chasing down a vacuum leak  (Read 5647 times)
godfire
Republic of Texas
« on: October 15, 2008, 08:30:08 PM »
I have a 98 standard and the Honda and Clymers manuals show a nice picture of where the vacuum hose routing should be......but on my bike there is only evidence of a long gone sticker.
Does anyone have a diagram of the vacuum routing of a non-california model?
Ride Safe
Ride Often
Wanderer
The Great Republic of Texas - Dallas
« Reply #1 on: October 16, 2008, 09:39:12 AM »
The first place to look is the most common place for failure, Jim. That has consistently been the middle cylinder on either side with the left side center most often times the first to leak due to heat and vac hose deterioration. Pull it off the barb (inboard just below and barley (isn't spell check a wonderful thang) forward of the #4 spark plug wire for the left side center) and turn it over and you will probably find your first leak. You may have enough length to clip it and reattach.
If you want to replace them all, my preferred method is to remove the air box to get at everything. As with an air filter change, it is easier to do with a near empty fuel tank. Let me know if you need/want more help.  ~Jeff
« Last Edit: October 16, 2008, 09:50:42 AM by Wanderer » Logged
More Valk Pics...
had a couple of Valks once upon a time
2004 DRZ400S
2005 GS1200
1978 CB550K
1977 CB550F
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #2 on: October 16, 2008, 12:43:45 PM »
You can trust Jeff on this one Jim.  Jeff pointed out to me that both of my vacuum lines were deteriorated to the point that they were flattened out and no longer vac'ing.  I pulled my airbox and replaced all of my hoses.  I will probably skip the desmog on my scoot for now since I went to all of the work and incredible expense ($3) of replacing the hoses.
Chuck
Super Santa
VRCC #27029
Houston, Texas
« Reply #3 on: October 18, 2008, 05:05:01 PM »
Just for future info, what size are those vacuum lines.  Thought I might just buy some and do them.  Sounds like good preventative maintenance.
godfire
Republic of Texas
« Reply #4 on: October 18, 2008, 09:48:44 PM »
Earlybird,
Check out Rich's website:
http://redeye.ecrater.com/
http://redeye.ecrater.com/category.php?cid=414983
He is very helpful, I ordered the wrong stuff and he saw right through me and got me what I needed.
Ride Safe
Ride Often
Houdini
Allen, TX
« Reply #5 on: October 19, 2008, 09:42:06 AM »
I went to Auto Zone and bought some hose off of the reel; I believe it was 5/16 OD but I don't remember for sure.  I took a small sample of good hose and just matched it up to what they had in the store.
Chuck
RainMaker
Arlington, TX
« Reply #6 on: October 20, 2008, 02:35:08 PM »
I just bought some hose and the quick gas tank disconnect from Rich per Godfire's suggestion and got an email from him today that the freight cost was incorrect ( a dollar high) and he is putting the dollar in the package he is sending to me.  So, not only does he have stuff we need, he's honest, too.
RainMaker
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
Jeff A
« Reply #7 on: January 19, 2009, 09:13:04 AM »
I have a 2000 IS.  I bought it on 3/1/08 from a guy who bought it new.  The bike had 13,000 miles when purchased, so it did a lot of resting.  I now have over 19,000 miles on it.
I have 2 problems.  First, when the bike gets hot it will not return to a normal idle.  Rather, it idles at or above 2,000 rpm.  2-3 cans of Seafoam and a fair amount of riding did not help.  The only thing that "fixes" this is letting it cool off.
Second, I have noticed some blueing of my exhaust pipes on the left side (as you are sitting on the bike).  This is probably caused by excessive heat.  However, the pipes on the right side are not discolored.
Some guys have said I have a vac leak.  Others, including the service mgr. at Al Lamb, said my carbs need cleaning/adjusting.  He wanted $600 for the job.  I passed.
I am inclined to start by replacing the vac hoses.  This seems like an inexpensive and relatively easy task (although my mechanical skills are easily tested).  However, I would like to hear from anyone who cares to chime in.  I am especially interested if you think me 2 problems are related.
Thanks.
Jeff Atkins
