January 28, 2026, 11:01:35 PM
pilot screw?
Topic: pilot screw? (Read 2118 times)
valkyalky
pilot screw?
June 29, 2009, 08:19:15 PM »
please tell me where the pilot screw(s) is/are. No I am NOT going to mess with it/them
Thunderbolt
Worthington Springs FL.
bottom of each carb
June 30, 2009, 05:10:49 AM »
in a recess. They have a "D" shape and require a special tool to turn. They are sorta toward the outside of each carb.
Re: pilot screw?
June 30, 2009, 07:44:23 AM »
They are located in the carburetors. If you look at each float chamber [bottom of carburetor]you will see a vertical part of the casting which is located toward the inside/center of the engine. In this casting is a pilot screw with 'D' shaped head..
