February 06, 2026, 10:08:36 PM
radiator cap gasket
Topic: radiator cap gasket (Read 1022 times)
bossman10728
radiator cap gasket
May 13, 2013, 09:56:16 AM »
Has anyone made a replacement radiator cap gasket instead of replacing the entire cap?
Re: radiator cap gasket
May 13, 2013, 10:09:26 AM »
Have you tried to tighten the prongs on the cap to make it seal better.
May 13, 2013, 04:59:52 PM »
As was said, slightly pinch the tabs on the cap. I also use a high vacuum silicone grease on radiator caps.
May 13, 2013, 08:22:45 PM »
Quote from: sandy on May 13, 2013, 04:59:52 PM
As in you lube the gasket?
