January 29, 2026, 03:36:01 AM *
Author Topic: Oil weight and capacity question  (Read 2831 times)
Jason and Amber (Ga)
Dallas, GA.
« on: June 30, 2009, 09:54:13 AM »
I know I know I know, this has been asked and answered numerous times and I apologize for yet asking again. I just don't know how to navigate the new site.
Anyhow, I have a 1997 Valk CT. I am planning a mountain trip this week and need to change my oil. I know I used synthetic Mobil 1 in my last few changes but don't recall the weight or amount. I think it was just under 4 qts. but want to be sure.
Also, would you change the coolant? I have owned her for just over a year and have not changed it. My uncle owned it prior to me since new and did a good job at having it serviced each year.
I just can't pay Honda to do something that I am able to do...
Once again, sorry for posing a frequently asked question and I will spend more time on here and become acustomed to the new site.
Jason
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: June 30, 2009, 10:16:07 AM »
An even gallon jug of whatever oil in the recommended range of 10/40 or 20/50. If synthetic, I run the 15/50 weight or 15/40. Change the filter.
Bone
« Reply #2 on: June 30, 2009, 10:26:45 AM »
Honda recommends every 2 years on the coolant. I will check the book later to make sure. I try and not change much before a trip unless there is a problem or mileage says it's due. Sometimes we create our own troubles.
MP
North Dakota
« Reply #3 on: June 30, 2009, 11:10:40 AM »
Non silicate antifreeze only.
"Ridin' with Cycho"
sugerbear
wentzville mo
« Reply #4 on: June 30, 2009, 04:24:17 PM »
use whatever oil your want. just make sure the bottom of the ring(on the back) does NOT say energy conserving.
i prefer mobil 1 15-50. just pour in 4 qts. it'll be fine.
3.9 something according to the book.
Dallas, GA.
« Reply #5 on: July 01, 2009, 07:48:27 AM »
Thanks guys! I used Mobile 1 (car oil) in the last oil change and everyone at the bike shops were like "YOU DID WHAT". However, I have 3,000 miles on this oil and no problems. I did get some Honda Gold (Semi-Synthetic blend) 10w-40 last night and plan on running that in this change.
I have also heard that once you use a full synthetic oil that you should never use a conventional oil again. Any thoughts on this??? cooldude
Valker
Wahoo!!!!
Texas Panhandle
« Reply #6 on: July 01, 2009, 08:15:45 AM »
My only thoughts are my experiences. I have switched back and forth between oil brands, weights, types (syn and dino) many times on my Valk in the past 110,000 miles. It still uses no oil between changes. I change it between 3000 and 10,000 miles.
Dallas, GA.
« Reply #7 on: July 14, 2009, 11:29:23 AM »
Thanks guys! I ended up using the Honda Golden Blend 10W40 (Synthetic/Conventional Blend). I can tell a huge difference in my shifting. Seems to be much smoother. Also I got a little over 30 mpg and usually only get 29 to just over 30 mpg. Nothing huge but a small difference. I won' tbe using car oil any longer. The Honda Gold was only $8 per quart so it didn't break the bank!
Had an awesome ride in the North Georgia Mountains and even had a burger at T.W.O. (Two Wheels Only) in Suchess, Ga.
We rode on Hwy 180 which is like a baby dragon tail. Light traffic and no one around us riding like fools! Can't wait to go to the Tail!
« Reply #8 on: July 14, 2009, 12:57:59 PM »
Why do you go with 'heavier' weight with synthetc then reg oil? I been using Mobil 1 high mileage 10w-40 for 2 years now with no prob. Gets around 80-90 deg here in Ind and 100 in in SD when we go. Never a prob. Is this ok?
DeathWishBikerDude
« Reply #9 on: July 14, 2009, 01:32:56 PM »
I would never spend $8 per quart for some marketing bs.
I will pay a little more for synthetic oil,but I've never known anyone who killed an engine that didn't have a few hundred thousand miles on them.
I use supertech synthetic from wally world,about $15 per gallon.
My bike runs silently,and when I adjust my valves,you can practically eat off the valve train.
 coolsmiley
