February 07, 2026, 12:07:25 AM *
Author Topic: Anybody use "Redline Supercool with Waterwetter?"  (Read 2631 times)
Fudd
MSF RiderCoach
Denham Springs, La.
« on: May 20, 2013, 02:01:35 PM »
 I see Supercool coolant on sale for $18/ 64 oz. at Cycle Gear.
Anybody have experience with it?
« Last Edit: May 20, 2013, 04:26:16 PM by Fudd » Logged
Save a horse, ride a Valkyrie
« Reply #1 on: May 20, 2013, 05:19:25 PM »
No experience but if it says silicate free; borate free; you're good to go. I use Prestone Dexcool and distilled water (50/50) and add Water Wetter to that mix. One gallon of Prestone ($13) makes 2 gallons of mix.
jmann
Mesa,Az.
« Reply #2 on: May 20, 2013, 05:40:06 PM »
Sandy, do you find that the water wetter helps lower your temps? If so how much do you use?   coolsmiley
« Reply #3 on: May 20, 2013, 08:01:53 PM »
I don't know if it lowers temp but I'd guess not as the T'stat regulates that. I use WW in the instructions on the bottle. I ride all summer in AZ and I figure it couldn't hurt.
jmann
Mesa,Az.
« Reply #4 on: May 20, 2013, 09:07:25 PM »
Thanks for the info Sandy. I ride in AZ all summer too. Every little bit helps. We actually have a mutual friend. Mr. Biemfor. He said you do a great job of installing progressive fork springs. If I tempted you with monetary rewards would you help me do mine?  Cheesy
Pappy!
Central Florida - Eustis
« Reply #5 on: May 20, 2013, 09:14:21 PM »
I used it.
1982 Jeep CJ-7 with a .060 over AMC 360 in it. All cammed up and ready to overheat at the slightest chance. Had a 4-core radiator in it but when in the deep sand in the forest around here it would run hot. 160 degree thermo.
The water wetter did not seem to do a darn thing.
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #6 on: May 21, 2013, 11:03:40 AM »
I was under the impression that once an engine reached a certain temp during warm-up the thermostat just opened up and stayed that way until the engine was shut down and it cooled off.
As far as WaterWetter is concerned, it is not an antifreeze, it is works like a surfactant, causing a reduction in the surface tension of water.  Circulating coolant, including water comes in contact with heated internal engine parts and actually even boils at the hottest areas.  Breaking the surface tension results in smaller boiling bubbles and more efficient heat transfer.
It is also my understanding that water is a much better heat transfer medium than glycol.  The advantage of antifreeze is it has a higher boiling point and a lower freezing temperature.  An engine can actually run cooler with water than antifreeze, which is the reason race cars use water treated with WaterWetter in their applications.
Here's what they claim:
ABOUT RED LINE WATERWETTER® COOLANT ADDITIVES
Reduces or eliminates bubbles or vapor barrier that form on hot metal surfaces to reduce coolant temperatures by up to 20°
Superior heat transfer properties compared to glycol-based antifreeze
Compatible with new or used antifreeze (including DEX-COOL and long-life versions) to improve the heat transfer of ethylene and propylene glycol systems
Improves heat transfer and reduces cylinder head temperature
Designed for use with all modern aluminum, cast iron, copper, brass and bronze cooling systems
Cleans and lubricates water pump seals
Reduces cavitation and complexes with hard water to reduce scaling
Does not lower cooling system below the thermostatically-controlled temperature
frosty
« Reply #7 on: May 21, 2013, 11:58:27 AM »
Use water wetter for several years and prob. 60k miles. I could tell ran cooler. Fan didnt kick on as before when  sitting in traffic. There was a tech. topic here years ago around 03 when I went to it. Changed antifreeze once since then. WW went back in.
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #8 on: May 21, 2013, 12:35:27 PM »
Would I be correct to assume that you use a 64 oz. mixture of Supercool with a 50/50 silicate free antifreeze?
