February 07, 2026, 12:08:41 AM *
Author Topic: Audiovox cruise control bracket  (Read 1166 times)
theredark
Derry, NH
« on: May 22, 2013, 03:26:36 PM »
Hi all,
I'm getting ready to install the Audiovox clone from Murphs kits (CCS100) and remember reading a post somewhere of how someone had used an auto parts store accessory to mount the control pad to the right handlebar area.  Does this ring a bell to anyone?  Or any other suggestions (other than duct tape) to mount it.  I don't have a machine shop available unfortunately!   Thanks as usual.    Brad
2000 Black/Red Interstate
Mr.BubblesVRCCDS0008
« Reply #1 on: May 22, 2013, 05:01:12 PM »
I used a small piece of alum. flat bar about 1/8in thick. Drilled a hole and mounted under the left hand mirror post. I bent it up at a small angle so I could run it with the same finger that works everything else on that side. Been there for years now.
theredark
Derry, NH
« Reply #2 on: May 22, 2013, 05:19:41 PM »
Thanks for the reply.  How did you attach the pad to the bracket?  Brad
bentwrench
Philadelphia,Pa.
« Reply #3 on: May 22, 2013, 06:04:51 PM »
I made a similer bracket,epoxied a 1/4" thick plastic block to with a channel cut toward the bottom to let the wiring out.then used 3m dbl.stick to mount the switch.Keep it covered when washing or rain riding.
BW
« Reply #4 on: May 23, 2013, 07:31:43 PM »
Mine is held on to the bracket with two sided 3m tape.
maniscar
VRCC #2225
Southern NH
« Reply #5 on: May 24, 2013, 04:20:37 AM »
I have not installed one yet, but planned to follow these instructions.
    http://www.valkyrieriders.com/shoptalk/cruise-control.htm
The control switch mounting is near the end.
   Rich
2003 Valkyrie Standard
wd40
Winnemucca, NV, Reno NV
« Reply #6 on: May 25, 2013, 12:31:43 AM »
If you want to get it mounted real quick, and make a proper bracket when you have time, a Mini Mag light mounting clip will fit on the handlebars.  Makes an instant mount.  In fact mine has been doing it's job for at least 4 years!  It slips around a bit; a small screw and nut will tighten it up, between the mount base and bars.  Snap it on and you'll see.  Just don't over tighten.
PhredValk
Edmonton, Alberta, Canada
« Reply #7 on: May 25, 2013, 01:35:53 AM »
If you want to do a real bang up job, see http://www.valkyrieforum.com/bbs/index.php/topic,21439.0.html
You'll have to go thru a few pages, but Fordmano's solution is epic! It starts on page 4.
Fred.
VRCCDS0237
