February 07, 2026, 12:07:28 AM *
Author Topic: Looking for cruise install pics in fairing  (Read 1132 times)
theredark
Derry, NH
« on: May 26, 2013, 06:01:57 AM »
Good morning all,
Well I did buy my cruise control from Murphs kits and am planning the install.  I plan to put the servo in the fairing and recall seeing a post with great pics showing cable routing, etc.  Do you think I can find them now?  I've been searching for a half hour now and have given up and have to ask for help in navigating the site!  Thanks for all the help with the bracket question earlier.
Brad
2000 Black/Red Interstate
BonS
Blue Springs, MO
« Reply #1 on: May 26, 2013, 06:59:26 AM »
This is from Kingbee's cruise control installation. He used the "optional" vacuum reservoir and located it in the fairing as well.
NITRO
Eau Claire, WI
« Reply #2 on: May 26, 2013, 10:50:37 AM »
Here is a pic of mine installed in the fairing. There is ample room for the servo, my two horns, and all that extra wiring. It's impressive how much space is inside that fairing. You won't have problems routing the wires and vacuum lines, getting everything hooked up under the air box was much more of a PITA IMO.
I did this install a couple of years ago when Murph's first started selling the kits and did NOT use a vacuum canister. I have had no problems, all I did was tap into two of the intakes with check valves.
(I was changing horns and risers in this pic)
When in doubt, ride.
PhredValk
Edmonton, Alberta, Canada
« Reply #3 on: May 26, 2013, 06:44:16 PM »
Here's a pic from Fordmano (hop it's OK FM). Massive power amp and CC100 under the faring..
Fred.
VRCCDS0237
dreamaker
Harrison Township, Michigan
« Reply #4 on: May 27, 2013, 06:05:22 AM »
WOW!!!!     That seams like killing a fly with a sludge hammer. I have the Vista twist grip, it seams much simpler and lighter.  That looks wild.
