February 07, 2026, 12:07:24 AM
Have You Rebuilt Your Front Master Cylinder?
Topic: Have You Rebuilt Your Front Master Cylinder? (Read 980 times)
Steve K (IA)
Cedar Rapids, Iowa
May 26, 2013, 07:54:33 PM »
Time to rebuild the front master cylinder on my 2000 I/S. Do I really need to order new oil bolt washers when getting the Master Cylinder Set?
States I Have Ridden In
Raverez
No good deed goes unpunished
Central New York State
Re: Have You Rebuilt Your Front Master Cylinder?
May 26, 2013, 08:01:54 PM »
Got a bunch of AN washers at my local Ace hardware store. Cost less but are the same.
Steve K (IA)
Cedar Rapids, Iowa
May 26, 2013, 08:21:41 PM »
Thanks for the tip.
May 26, 2013, 08:27:05 PM »
Steve, do you have a Mighty Vac to pull the clean fluid through the system?
It makes for a cleaner and quicker flush, and bleeding of the system.
If not and you want to borrow mine, just call and come get it, when done bring it back.
