January 29, 2026, 12:50:20 AM
A question for you painters.
Topic: A question for you painters. (Read 1895 times)
July 01, 2009, 10:00:29 AM »
Recently had a box built of diamond plate aluminum for my one-wheel trailer. The bike is black and if it's not too involved I'd like to spray the box to match. What would be the process needed to spray it black, do I have to rough it up all over first with some sandpaper, or can I get by using a self-etching primer first then spray it black? It looks fine all nice and shiney the way it is, just would like to have the color match the bike is all.
Re: A question for you painters.
July 01, 2009, 10:33:13 AM »
If the self etching primer will work on your material, I wouldn't give it a second thought! Otherwise a little scuffing would be indicated.
junior
new hampshire
July 01, 2009, 02:15:58 PM »
what you want is epoxy primer, wipe the alum. down with body prep and a scotch bright pad do a final wipe down, spray the epoxy. i have had the best luck with dupont ful-poxy. then you can spray over that with what ever you wanted
JimC
SE Wisconsin
July 01, 2009, 05:17:41 PM »
+1
on the epoxy primer after wiping down with some aluma-prep, (found at most automotive paint stores) Dupont or PPG will work just great
Jim
Jim Callaghan SE Wisconsin
Thanks for the info.
July 01, 2009, 05:39:52 PM »
I have some scrap diamond plate, might experiment on that first before going for the real McCoy.
