February 07, 2026, 12:08:38 AM
carb help
Topic: carb help (Read 1059 times)
jrcody1127
carb help
May 28, 2013, 05:21:36 AM »
does anyone know what the rubber hose is for at the top of the #6 carb and it runs down to the carb frame at the rear of the motor and it is just open, hanging kike a carb bowel drain. it is about 3/8". i have agas leak at the #6 and #4 carb. thought it was the carb bowels, put new gaskets and still leaking. maybe the fuel line or rail.?
thanks
Re: carb help
May 28, 2013, 05:37:41 AM »
It's probably one of the two overflow lines on each carb bank. If it's leaking fuel, you might have a stuck float.
Has the bike been stored awhile?
My rides:
Re: carb help
May 28, 2013, 05:40:14 AM »
carb bowl vent line. the other bank has one also.
Thunderbolt
Worthington Springs FL.
Re: carb help
May 28, 2013, 02:17:45 PM »
What they said, it is probably the overflow line from that side. If gasoline is coming out there, you have a float stuck. You might be able to tap the bowls with a screwdriver plastic end a few times and dislodge it. Otherwise you will probably have to remove the carb bank to correct it. I usually hook up an external tank to the carb bank before I install it to check for that type of problem.
