February 07, 2026, 05:45:45 AM
Rear Engine Seal By Yoke
Topic: Rear Engine Seal By Yoke (Read 1214 times)
trout dude
Hammond Louisiana
May 28, 2013, 02:35:00 PM »
i have oil leaking from the seal in between the engine and the yoke. It is getting in the boot. Does anyone know if i am able to change this seal without dropping the swing arm or removing the engine? Any info would be helpful.
Thank you,
Dennis
Daniel Meyer
The State of confusion.
Re: Rear Engine Seal By Yoke
May 28, 2013, 03:12:48 PM »
Yep, done it.
Follow the instructions for u-joint removal here:
http://www.rattlebars.com/mtz/ujoint.html
You don't need to pull the swing arm or pipes.
Once the ujoint is out, the seal holder just unbolts with 3 I think, maybe 4 bolts. Change the seal and o-ring and put her back.
Easy money.
CUAgain,
Daniel Meyer
Daniel Meyer
May 28, 2013, 03:13:31 PM »
Also, buy a new boot. They are cheap, and new will go on MUCH easier than the old oil-soaked one...
CUAgain,
Daniel Meyer
trout dude
Hammond Louisiana
May 28, 2013, 03:57:27 PM »
Thanks Daniel I have the seal i will get the boot and o-ring where dose the o-ring go
Thanks Dennis
Daniel Meyer
May 28, 2013, 04:13:38 PM »
Quote from: trout dude on May 28, 2013, 03:57:27 PM
Thanks Dennis
O-ring goes between the seal holder and the engine case. Seal holder just bolts to the engine. It's an easy swap.
CUAgain,
Daniel Meyer
trout dude
Hammond Louisiana
May 28, 2013, 04:20:40 PM »
Thanks again Daniel I should have it apart by tomorrow and will let you know how it goes
Dennis
trout dude
Hammond Louisiana
Reply #6 on:
May 28, 2013, 04:48:27 PM »
Daniel Just went and found my seal and my bud at the honda shop stapled the o-ring and seal bags together did not know he put the o-ring with it so i have both
Thanks for your help Dennis
trout dude
Hammond Louisiana
Reply #7 on:
June 10, 2013, 04:54:43 PM »
Daniel Meyer I would like to thank you for all the input it made fixing this oil leak very simple
Thanks Again Dennis
Daniel Meyer
Reply #8 on:
June 10, 2013, 06:51:59 PM »
CUAgain,
Daniel Meyer
