February 07, 2026, 12:08:28 AM *
Author Topic: trunk wiring? one more ?  (Read 1007 times)
andersonk.2009
« on: May 28, 2013, 10:07:22 PM »
thanks for your help. I also have a cargo trailor which ill need to have a plug for. Can i also tie in the plug where i will be wiring the trunk plug @ will i have problems with fuses? thanks.
« Reply #1 on: May 29, 2013, 08:01:26 AM »
Whenever adding trailer wiring to a motorcycle, you will need to use a powered taillight converter.  Motorcycles (or any vehicle with yellow turn signals) have the turn signals isolated from the brake lights, while most trailers use the same light bulb filament for turn and brake. A converter will take care of this.  Also, a POWERED converter powers your trailer lights directly from the towing vehicle's battery, rather than overloading the towing vehicle's taillight wiring circuits.  Here are a couple of examples of such a device:
http://www.reeseprod.com/content/products.aspx?lvl=3&parentid=1500&catID=1535&part=119190
http://www.hopkinstowingsolutions.com/products/vehicle-wiring-connectors/power-taillight-converters/short_proof_power_converter.html
