March 10, 2026, 09:57:57 AM *
Author Topic: wind shield cleaning ideas  (Read 1855 times)
mhammer
« on: July 01, 2009, 03:21:38 PM »
what is a good way to clean a wind shield on a valk interstate. are there any good products for doing this.  thanks
2tonevalk
Whazzup????
« Reply #1 on: July 01, 2009, 03:48:34 PM »
Plexus, Honda Cleaner, to Pledge are used to clean the windshield.  Use up and down strokes only.  Also you want to use a soft cloth or microfiber cloth so as not to scratch the shield.
More importantly than what to use is what NOT to use.
Dont use Rainex.  It will discolor the acrylic.
Hope this helps.
Ride safe
Black Pearl's Captain
Emerald Coast
« Reply #2 on: July 01, 2009, 04:08:25 PM »
Only two things should ever touch your windscreen, warm water on a soft cloth or Plexus wiped with a soft cloth.
Raymond
Michael K (Az.)
Glendale, AZ
« Reply #3 on: July 01, 2009, 04:37:04 PM »
Dried bugs? All crusty on the shield? Hydrogen peroxide! Spritz on, after a minute chunky bug stuff turns to goo, wipes off without scratching. Then I use Plexus to make it all slippery again!
Just sayin----
FryeVRCCDS0067
Brazil, IN
« Reply #4 on: July 01, 2009, 05:22:24 PM »
I carry two microfiber cloths on the scooter. A wet one in a zip lock bag and a clean dry one. Any time it’s needed I wash the shield with the wet cloth turning it often so as not to rub the bugs and crud into the shield which would scratch it and then I dry it with the other microfiber cloth.
At home after I wash it as outlined above I use S100 detail and wax aerosol on it. This keeps it easy to clean but should be skipped if you expect cold rain on a hot day since it seems to cause more fogging.
« Reply #5 on: July 01, 2009, 05:44:35 PM »
I used some HD stuff before and worked good. Ran out and use honda polish. I use plexis once in awhile. Also carry the micro fiber cloth. When its heavy soiled on the road I'll soak a hotel towel in the hot bath tub water. Lay it on for a few min and everything is soft. I wipe all directions and I can see out the screen just fine. I have used rain X before when I 1st got the bike. Then I joined the VRCC and they said to never use it. Haven't since then but it had no ill effects on the screen.
sheets
Jct Rte 299 & 96, Calif.
« Reply #6 on: July 01, 2009, 06:14:58 PM »
 . . . copious amounts of hot water and a soft rag.  Hot water to reconstitute the dried bugs and bug bones.  Soft rag to gently wipe away.  Rinse often.  Do not use a paper towel, especially the gas station kind.  Once the crunchy stuff is gone follow up with the polish of your choice.  Ymmv,
« Reply #7 on: July 01, 2009, 06:31:37 PM »
Orange Pledge. Way cheaper than Plexus.
RTaz
Oscoda, Michigan
« Reply #8 on: July 01, 2009, 06:47:22 PM »
                 Clean the windshield and the whole bike this stuff is great...and Joe is a Valk riders and vendor....
                                            http://www.joes-juice.com/
« Last Edit: July 01, 2009, 06:49:07 PM by RTaz » Logged
 RTaz
DeathWishBikerDude
« Reply #9 on: July 01, 2009, 08:33:15 PM »
I try to touch my wind screen as little as possible.
I usually set a wet towel on the shield for an hour or so before washing to loosen bugs.
No matter what you use,you will scratch the shield eventually.
I get a new clearvue every 5 years or so.
The world looks so much better through a sparkling clear shield. cooldude
sugerbear
wentzville mo
« Reply #10 on: July 01, 2009, 08:34:34 PM »
i polished out the scratches on my CLEARVIEW a few days ago with maguires cleaner and polish. worked very well.
NCGhostrider
Jacksboro, TX
« Reply #11 on: July 01, 2009, 08:35:26 PM »
I have used Plexus, and now use Pledge.  I usually try to get the big bugs soft with a bit of warm water and then go at it with the Pledge.  It seems to prevent crazing and I have been doing it for years without ill results.  I found out it works pretty well on the instrument cluster of my old ford truck also.
99 I/S
NCGhostrider
Craig
Waiting for cooler weather, then I will gripe about it being too cold!!!
« Last Edit: July 01, 2009, 08:49:08 PM by NCGhostrider » Logged
#6674
99 I/S
Dogg
Berlin Md
« Reply #12 on: July 01, 2009, 08:40:56 PM »
Just sayin----
Dude....it works....I laughed, then tried it..omfg..lol
Michael K (Az.)
Glendale, AZ
« Reply #13 on: July 01, 2009, 09:16:21 PM »
It's like getting an E-ticket pass to Mushybugland!!
