I bought a batwing fairing off of an ol' boy on the side of the road. He didn't know anything about the manufacturer. I could not pass up the deal ($15.00) but I have no idea who made it.
1) It has 5 holes to mount a windshield
2) It had a complete ring, with holes, around the headlight hole, like a headlight was supposed to mount there.
3) It had a.......piece below the headlight ring that would have wrapped around the front forks.
4) It has 4 mounting bolts on the inside.
I say it "had" several things because it would not fit until I cut those pieces off.
The mounting studs did not align (I knew upon purchase all of the above) so I manipulated flat bar to make mounts from the studs to my MS fork mounts.
A CLub BRother gave me a HD three hole shield, none of the holes (except the middle) lined up so I drilled the 4 remaining holes in the lexan and mounted it anyway. It turns out to look great however the HD is approximately 1/2" to narrow. The best measurement I can get is 23" from outside edge to outside edge.
Any ideas on Manufacturer?
If I can figure out how to post pictures I will, Finished product only
