September 12, 2025, 03:41:53 PM *
Author Topic: Adjustment near brake pedal?  (Read 772 times)
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« on: June 08, 2013, 06:04:36 AM »
What is the black plastic thread adjuster near the brake pedal for?  Mine seems to be slightly loose when not applying the brake.  I think it has been that way forever.
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
« Reply #1 on: June 08, 2013, 06:08:59 AM »
Brake light switch. It pulls when applying the pedal.
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #2 on: June 08, 2013, 06:10:42 AM »
Thanks for the fast answer.
pancho
Bonanza Arkansas
« Reply #3 on: June 08, 2013, 06:26:06 AM »
You do not want to adjust it until it is tight,, that would cause the brake light to be on all the time,, it should be adjusted so that 1/2 inch or so of brake pedal movement causes the brake light to come on.
