January 29, 2026, 12:58:03 AM
question about dark side
Topic: question about dark side (Read 1701 times)
KCvalk
Alexandria VA
July 03, 2009, 12:52:13 AM »
understand the idea of taking off the inner bolt clamps from the rear fender but what do you use to reattach the grab rails and or aftermarket side bags?
do you just get a smaller bolt and nut that attaches to the inner fender alone or fabricate a 2-3" flat metal plate to add some strength to the plastic fender?
Im looking to put on a set of saddleman bags with the chrome bag rail spacer...but what to secure them with? thats with the altimax 60 tire
the armor of the Valkyries "sheds a strange flickering light, which flashes up over the northern skies" making the aurora.
Re: question about dark side
July 03, 2009, 03:52:17 AM »
What kind of a bike do you have that has a plastic fender on it.....
On mine we run the bolt through the fender from the inside. Used a carriage bolt and an acorn chrome nut...
Thunderbolt
Worthington Springs FL.
Yes to what RJ said
July 03, 2009, 03:59:40 AM »
I think I used a stainless steel 3/8" carriage bolt from the inside and a couple of nuts then bag rail then another nut.
DeathWishBikerDude
July 03, 2009, 04:44:16 AM »
I just use a standard nut on the inside of the fender.
The original nut plate is quite thick.
I'm guessing you save about 1/2 inch on each side of fender,using a standard nut.
