January 29, 2026, 12:56:29 AM
A rule of thumb?
Topic: A rule of thumb? (Read 2140 times)
Andy
A rule of thumb?
July 04, 2009, 07:26:51 AM »
I bought led turn signals with one each red and white wire. Can't find the instructions so don't know which is ground.
Is red hot and white ground as I'm trying out my feeble memory here?
Re: A rule of thumb?
July 04, 2009, 07:59:11 AM »
Andy, no rule of thumb because different manufacturers use different colors. It shouldn't hurt them by simply testing them on a 12v source. Just try it with red as ground and white on 12v, if they don't light up simply reverse the wires and try again. I have an external connector for my Battery-Tenda hook up, I just stick the wires in there to test lights. Never had an LED fail after testing like mentioned above.
Kingbee
VRCC# 576
Northern Illinois
July 04, 2009, 08:05:49 AM »
White "should" be ground, but no harm done if hooked up wrong.
1999 Interstate
2000 Interstate
2004 Rune
Grandpot
Fort Mill, South Carolina
July 04, 2009, 02:43:24 PM »
My thumb said, "Vote for the white wire being ground."
Like John said, hook it up one way, if it doesn't work hook it up the other way. You will not damage it. ???
Experience is recognizing the same mistake every time you make it.
Madmike
Campbell River BC, Canada
July 04, 2009, 06:57:12 PM »
If you hook them up backwards do they absorb light??????????
Grandpot
July 04, 2009, 07:16:47 PM »
Madmike:
Yes they do and then the stored light can be used later.
Did you ever try to calculate the speed of dark?
Andy
Reply #6 on:
July 05, 2009, 04:28:29 AM »
Thanks y'all
Reply #7 on:
July 05, 2009, 06:09:24 AM »
You can usually figure the following colors are ground.
White,
Green,
Brown, or
Black.
Reds are usually hot wires in 99.9% of the cases....
