February 07, 2026, 04:00:47 AM *
Author Topic: Vibration not the good kind..  (Read 1281 times)
cheeseman1969
Hastings NE
« on: June 18, 2013, 08:16:00 PM »
On a east coast trip.. Did 3000 miles. About 300 miles ago noticed a vibration 70 and above, then started to move down to 65 today. Had some cupping on the wheels so got them replaced in a honda shop in Greenboro NC. Next 50 miles was ruff.. Vibrations worst and worst and now down to 55 too. Then parked, grabbed phone and started to research. Read on here final drive transmission or something. Just did not want it to quit in the middle of now where and take more time to get it home to Nebraska. So put it in a uhaul. And heading home now. Any ideas what is the exact cause? Or close?  After this trip and uhaul 1200 miles, no more money for touring till maybe next year so have to tear this apart myself and dont mind but want astarting point.
Gary "Cheeseman"
USN "weather guesser" Retired
Been everywhere...
Rio Wil
« Reply #1 on: June 18, 2013, 08:42:32 PM »
Good possibility your ujoint is going south.  How many miles on the bike? When was the final drive/drive shaft splines inspected and lubed?
Michvalk
Remus, Mi
« Reply #2 on: June 19, 2013, 04:53:51 AM »
Have to side with Rio Wil. Most likely suspect would be the universal joint. Not likely trans. Pull the rear and inspect the drive shaft and u-joint, rear wheel bearings, and drive splines. Bet you find it in there cooldude
« Reply #3 on: June 19, 2013, 05:21:29 AM »
+1
My rides:
Loby
« Reply #4 on: June 19, 2013, 09:37:16 AM »
I just went through a vibration issue  with my 99 IS . The left rear wheel bearing was going bad.  It was a easy fix. Smooth as silk again.
cheeseman1969
Hastings NE
« Reply #5 on: June 20, 2013, 05:45:50 AM »
Hey thanks all. When i get home on Sat, I will taking the back end apart first and go on from there. I will keep it posted on updates on what i find. Thanks again..
Gary "Cheeseman"
Been everywhere...
tbone
Bradford, il
« Reply #6 on: June 21, 2013, 01:14:15 PM »
I have had both- rear bearing vibration and u-joint. The bearing was much worse and got bad quick. really felt it in the foot pegs. The u-joint was not as bad and showed up mostly in a coast type roll. usually on hills as I crested and started down. Wish you all the luck. Had mine in the shop twice for the u-joint. Could not feel any play or roughness until it was on the bench. felt tight it the bike.
