February 07, 2026, 04:00:47 AM *
Author Topic: What's Inside These Pipes?!! UPDATED  (Read 1895 times)
t-man403
Valk-a-maniac
Calgary, Alberta, Canada.
« on: June 18, 2013, 09:20:30 PM »
Just had to look, so now what?!!   uglystupid2
I'm thinking I can do a re-wrap with Rockwool.
« Last Edit: June 22, 2013, 02:04:22 PM by t-man403 » Logged
al v
Clinton Township, MI
« Reply #1 on: June 18, 2013, 09:53:28 PM »
And now you know...
You can rewrap that. Just need some intact fiberglass wrap.
Motorider
Pennsylvania
« Reply #2 on: June 19, 2013, 11:27:51 AM »
That sure looks like it would cause a lot of back pressure!
YoungPUP
Valparaiso, In
« Reply #3 on: June 19, 2013, 07:20:01 PM »
Holy Crap! It ran that way!!!
99 STD (Under construction)
Cotton Mouth
VRCC # 28922 Southern Nevada
« Reply #4 on: June 20, 2013, 05:43:33 AM »
That's where all my hair went, wow!  tickedoff
1999 I/S SOLD BUT NOT FORGOTTEN Jan 2015
1998 HD Road King Classic
« Reply #5 on: June 20, 2013, 05:59:16 AM »
You have a lot of mice!  Grin
tank_post142
south florida
« Reply #6 on: June 21, 2013, 04:12:35 AM »
there is a straight through tube with louvers cut into it. this wrap is around the outside of the tube and deadens the sound with very little restriction.
I got a rock Sad
VRCCDS0246
t-man403
Valk-a-maniac
« Reply #7 on: June 21, 2013, 07:32:41 AM »
That is correct.
I just couldn't figure out how they got all of it in there as it just fit back in with half of it cut off. I think that maybe they used that much to help reduce the heat on the chrome and perhaps prevent bluing or burning a leg.
I have picked up some new packing and will get it fixed up this weekend.
t-man403
Valk-a-maniac
« Reply #8 on: June 22, 2013, 01:36:01 PM »
Well I'm glad I took a look at why the right side had a different sound than the left.
I pulled the right side apart and found the wrap had been compromised.  Roll Eyes
This is what the pipe looked like with the baffle pulled out.  ???
I got it out using a coat hanger .......... modified!  Wink
Residential insulation!  Shocked
I wrapped the baffles with this, using masking tape to secure it so I could insert the baffles back into the pipes.
Now the pipes sound the same!  cooldude
Michvalk
Remus, Mi
« Reply #9 on: June 22, 2013, 03:29:42 PM »
Masking tape could catch fire! cooldude
t-man403
Valk-a-maniac
« Reply #10 on: June 22, 2013, 04:44:01 PM »
I highly doubt it as there is no air space between the outer pipe and the wrapping. Even if it did, there is nothing to damage.  coolsmiley
