February 07, 2026, 04:02:17 AM *
Author Topic: What could cause a "rod knock" sound on cylinder #6?  (Read 1675 times)
Momz
ABATE, AMA, & MRF rep.
« on: June 21, 2013, 11:16:44 AM »
My motor has been apart and everything is within spec. The rods were checked for straightness, bearings and piston pins were well within tolerance as well as piston to bore clearances, and crankshaft end play was also OK.
Expert engine opinions would be appreciated.
Thank you.
ALWAYS QUESTION AUTHORITY!
« Reply #1 on: June 21, 2013, 11:29:42 AM »
Was the engine taken apart due to this noise ?
Momz
« Reply #2 on: June 21, 2013, 11:33:55 AM »
Yes, and after a hydrolock fix.
« Reply #3 on: June 21, 2013, 12:14:55 PM »
George, these flat engines will knock like crazy if the carbs are out of sync real bad.
Oklahoma_Valk
Central OK
« Reply #4 on: June 21, 2013, 01:25:43 PM »
Keeping with John's advice,
If one cylinder is not getting fuel, and the rest ARE getting fuel, the lean cylinder will knock. Im assuming your valve tolerances are correct as well.
Let those who ride decide.
« Reply #5 on: June 21, 2013, 01:53:34 PM »
I'm also wondering if there could be a problem with one of the starter drive gears.
Momz
« Reply #6 on: June 25, 2013, 08:29:49 AM »
It seems that you may have a point.
Would seem rather odd with the motor components in spec, and #6 cylinder closest to the starter drive mechanism.
Momz
« Reply #7 on: June 25, 2013, 08:34:48 AM »
Carbs were synced less than 600 miles ago. They were rebuilt and rejetted, then synced after reinstallation.
