February 07, 2026, 04:01:41 AM
Mounting CB under seat on IS?
Topic: Mounting CB under seat on IS? (Read 914 times)
nerider2
Omaha, NE
June 29, 2013, 09:14:52 PM »
Does anyone have photos or instructions on putting the CB under the seat in the battery box for a supervalk?
Ed
2014 Daytona Blue Ultra Limited
2000 Stealth Interstate
1999 Excelsior-Henderson
Omaha, NE
VRCC #23874
Iron Butt Association #32532
fantsybikr
O HI O
Re: Mounting CB under seat on IS?
June 30, 2013, 06:32:59 AM »
I used a dremel tool with cutoff wheels and cut out the divider at the rear of the box. The cb will lie in there at an angle, on its side, I used foam to pad the bottom of the box as so the cb to ride on it. Be sure is a foam that is made to handle some heat. I also had to "notch" a hole on the side of the box, toward throttle side, to give the wires a place to get out and to let the cb fully rest inside of box, a little notch in bottom of box with matching notch in lid, file the rough off and maybe even find some type of rubber seal to protect the wires..something like goes around the glass in storm windows or something similar.
If I remember correctly cutting along the bottom was easier than the sides with dremel, I might have even used a hacksaw blade to cut sides down, either in a tool that holds a blade out the end or a blade with a set of vise grips clamped to it as not to rip your hand while sawing with it.
hope this helps..I am better at cutting the box an uploading pics but can try if no one comes up with any and you need them
VRCCDS 0252
VRCC 26284
GWRRA 329832
nerider2
Omaha, NE
June 30, 2013, 11:46:45 AM »
Got it, it seams to work fine, thanks for your assistance.
Omaha, NE
VRCC #23874
fantsybikr
O HI O
June 30, 2013, 12:48:46 PM »
Quote from: nerider2 on June 30, 2013, 11:46:45 AM
VRCCDS 0252
VRCC 26284
GWRRA 329832
