November 25, 2025, 08:48:00 PM
Cruise control troubleshooting
Topic: Cruise control troubleshooting (Read 690 times)
forjj
Luray, VA
July 02, 2013, 05:53:45 PM »
OK, so my audiovox cruise died on me a while ago. I checked the white wiring harness, and didn't like the look of it(a little corrosion), so I connected all of them with crimp connectors instead. Then I discovered the cable that connected to the throttle was broken. I fixed the broken cable, but sill no cruise. I am going to re-check all of the connections, but now I am wondering --- Is there any calibration required with the electronics, or did I just screw up the wiring???
2000 Interstate Blue/Silver
2005 Corvette
1989 F250 Diesel
1979 Ford 1100 Diesel Tractor
"I don't know where I'm going, I see no reason in being late"
olddog1946
Moses Lake, Wa
Re: Cruise control troubleshooting
July 02, 2013, 07:10:32 PM »
My understanding is that the only calibration adjusments are for sensitivity and centering (drift between high and low speed while engaged.
If you have nothing, check your kick out switched (control pad, brake switch, tach connection) if they check good bite the bullet and buy a replacement unit.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Moses Lake, Wa. 509-760-6382 if you need help
=> InZane XXV
