February 07, 2026, 09:46:13 AM *
Author Topic: Carb Sync Guages  (Read 2497 times)
Maldog
Woodstock IL
« on: July 05, 2013, 08:59:35 PM »
Was  thinking about  gettin a set of  guages for syncin da carbs wold like to get 6 of course most sets ive seen have 4  did the guys  on you tube ive seen with 6 guages make ther own  or can u buy  2 extra guages  also if   ya made your own guage set  can you adivse me as to a list of what u need to make them and the best place  as far as quality and price  to  obtain the   necessary stuff Thanks guys Cool
mmurffy03
03 standard
toms river new jersey
« Reply #1 on: July 05, 2013, 11:58:00 PM »
I have the hondaline 4 guage setup where you do 4 then the other 2
this set works good also
« Last Edit: August 03, 2013, 02:49:34 AM by mmurffy03 » Logged
N8171S
Marlboro, Mass
« Reply #2 on: July 06, 2013, 03:44:32 AM »
I bought two sets of 4 from JC Whitney.  These use mercury tubes.  Just hook up 6  They work good.
whitestroke
San Pedro, Ca.
« Reply #3 on: July 06, 2013, 10:23:12 PM »
Valkyrie Carb sync harbor freight gaugespowered by Aeva
Harbor freight, with a set of plastic sprinkler valves from Ace. Under a hundred for everything.
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
Maldog
Woodstock IL
« Reply #4 on: July 07, 2013, 07:19:40 AM »
Hay Thanks Whitestorke ,lol actually  your vid is what got me headin down this road  , can ya help a brother out with some part numbers  for them there guages,was all the tubeing included with the guages or do I need to buy it and if so what size id & od  and that spiniker valve  from Ace  is there a size I need to be aware of  Tha.nks  Bro
« Reply #5 on: July 07, 2013, 07:57:18 AM »
whitestroke What did you use as restrictions in line? By the way nice bike and nice setup.
« Reply #6 on: July 07, 2013, 08:40:24 AM »
 Twinmax Electronic Carburetor Balancer.
good write up
http://advwisdom.hogranch.com/Wisdom/TBS4Dv1.0.pdf
or morgan carbtune
http://www.carbtune.com/carb.html
« Last Edit: July 07, 2013, 08:59:28 AM by CA » Logged
whitestroke
San Pedro, Ca.
« Reply #7 on: July 30, 2013, 09:29:52 AM »
Vacuum Tubing is 5mm or 13/64
Tubing fits sprinkler valves(restrictors), gauges and manifold.
« Last Edit: August 01, 2013, 10:14:38 PM by whitestroke » Logged
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
« Reply #8 on: August 01, 2013, 04:59:23 PM »
Twinmax  cooldude cooldude
Been using one for 10 years or so, easy to use and store.  I remove the battery when not using it, cause they seemed to go dead.
cantom
Ontario
« Reply #9 on: August 01, 2013, 05:14:16 PM »
I just received a Morgan carbtune setup 2 days ago. Will get around to it soon, I swear... Roll Eyes
You do 4 then the other 2. A much better setup than using mercury which can get sucked into the cylinders.
I prefer this setup over dial gauges with restrictors.
http://www.carbtune.co.uk/c.com/
AZdougness
« Reply #10 on: August 02, 2013, 12:25:36 PM »
This is what I came up with after some free time and the help of McMaster-Carr
matt
Derry New Hampshire
« Reply #11 on: August 02, 2013, 01:10:18 PM »
I like the looks of that, How much did it cost?  and part #,s  Please   Thank You
« Reply #12 on: August 02, 2013, 02:28:47 PM »
I kept my simple. It has a 4" face and only $24 from Oreillys.
My rides:
« Reply #13 on: August 02, 2013, 02:43:15 PM »
I like things simple too. I've said this soooooo many times over the years. I use one single plain ole gauge. Since Honda says 1.6 in/hg is their spec, so, this adjustment is no big deal. The single gauge will get you within a needle width which is better/less than .5 in/hg.
AZdougness
« Reply #14 on: August 03, 2013, 02:37:31 AM »
If I had to do this again I would probably go smaller gauge size and have used a needle valve instead of a ball valve. No doubt it cost much more to do the gauge setup than a manometer.
3941K74 http://www.mcmaster.com/#catalog/119/574/=nwg4gu
50785K26 http://www.mcmaster.com/#catalog/119/36/=nwg5zv
5346K81 http://www.mcmaster.com/#catalog/119/292/=nwg5up
5231K34 http://www.mcmaster.com/#catalog/119/125/=nwg6cr
I highly recommend McMaster to everyone I know, they have excellent products, as well as fantastic customer service.
