November 25, 2025, 09:12:28 PM *
Author Topic: Indicator lights  (Read 1847 times)
Sam Shlitz
SoCal
« on: July 06, 2013, 03:57:30 PM »
I need to replace neutral gear indicator bulb. I have a hard time seeing it in the bright sun light.
What type of bulb is it and where can I buy a brighter replacement? Thank you fellas for your help
chrise2469
Winnipeg Manitoba Canada
« Reply #1 on: July 06, 2013, 05:05:17 PM »
You don't mention if you have a std/tourer or an interstate.
The standard uses a T6.5 12v 3watt.
I did a write up with  led's and honda rebel harness here
http://www.valkyrieforum.com/bbs/index.php/topic,35394.0.html
You can use the led here without having to change the harness.
http://www.superbrightleds.com/moreinfo/subminiature-bulbs/24-led-bulb-1-smd-led-wedge-base/229/
If you have any questions let me know. Ride safe.
Chris
Sam Shlitz
SoCal
« Reply #2 on: July 06, 2013, 05:33:11 PM »
Thank you Chris, I appreciate your quick reply. Already placed my order.
