November 19, 2025, 02:46:20 PM *
Author Topic: tire patch  (Read 1543 times)
zoltan57
Denver, Colorado
« on: July 06, 2009, 10:47:21 AM »
hey. i found a flat head screw right down the middle of my front tire... when i got home the flat head sheered off.. i so far im still holding have avons.. so can a plug and patch work.. or tube... and will a dealer do it..
roboto65
Conroe,TX
« Reply #1 on: July 06, 2009, 11:07:19 AM »
Me personally would not plug or patch the front maybe the rear. Now as for the innertube well I probably would do that if the tire was fairly new !!!
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
semo97
Texas
« Reply #2 on: July 06, 2009, 11:16:26 AM »
Did you pull the screw out to see if it went all the way thru? It may have not.Then you are good to go. If it went thru was it a large one? When you plug you will ream it first and that will make the hole larger. I would put an inside the tire patch, I do not think a dealer would do it due to liability resons. Plugs are good in a pinch, some go many more miles with them, I do not. I do all my own tire work so I make the call to patch or get a new tire. I would not tube  it unless it is a bius ply tire.
